Use ezio2x3 with relay from UPS.
Hi,
I currently have a UPS which has a relay output that I've been using with a 2350 connect to the S and GND inputs so it can trigger some Insteon things.  I'd like to use this somewhere else, so I got a ezio2x4.  For the life of me I can't figure out how to connect the two.  Can anyone tell me what connections I should use on the ezio2x4 to mimic what I was doing with the 2350?
Simon
You are using a 2450 I/OLinc?
The EZIO2x4 has opto isolated and digital inputs.
Connect I1+ or I2+ {Depending on which one you want to use}  to the 5 volt connection on the EZIO2x4.
Your relay output from the UPS to I1- or I2- and the GND terminal on the EZIO2x4.
Edited by Brian H
hi brian,
thats right using a 2450.  thanks for the this, i am going to give it a go.
simon
hi brian,
i just tried what you suggested and it worked like a charm.  thanks!
simon
