Range extender
I suspect it is required component of Insteon communications much like  the MAC address of any ethernet capable device.  My Access Points have ID's too.  Neither the Access Points or Range Extenders are linkable devices however.
That makes sense. It's too bad they don't show up in the ISY so we could note their locations.
You may also find the FCC ID number on it is for a 2457D2 LampLinc. Mine is a 2457D2 Lamplinc board  with the dimmer components and output AC connector removed.
Maybe different on the newest hardware presently being sold.
I tried to add it to the ISY just to see what would happen and it came up as an unknown device
I am not surprised it can't be added.
I would suspect it has its own firmware to make it act like a signal repeater and not a lamp module.
Xathros,
Just got a reply from Smarthome. Not sure what there is to monitor. If they can be added to the Hub then why not to the ISY?
      Thank you for contacting Smarthome.
      The range extenders have Insteon addresses so that you may add them to your Insteon Hub and monitor it from your mobile device.
It is not a controller or responder.  So what can be monitored? Its not On Off or anything in between.
I did try and add mine. Using both the Auto Discover and Manual Linking method.
Event Viewer Level 3 did show some communications between PLM and the Range Extender.
Maybe Smarthome is pinging it with a message and just seeing if it responds.
Event Viewer Level 3 communications with a Range Extender trying to add it.
Auto Discover:
Thu 05/28/2015 07:12:31 PM : [23 53 57    ] Added to list of devices to link to ISY
Thu 05/28/2015 07:12:32 PM : [iNST-TX-I1  ] 02 62 23 53 57 0F 0D 00
Thu 05/28/2015 07:12:32 PM : [iNST-ACK    ] 02 62 23.53.57 0F 0D 00 06                 (00)
Thu 05/28/2015 07:12:32 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 AF 0D FF           (FF)
Thu 05/28/2015 07:12:32 PM : [std-Direct Nack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Thu 05/28/2015 07:12:32 PM : [iNST-TX-I2CS] 02 62 23 53 57 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Thu 05/28/2015 07:12:32 PM : [iNST-ACK    ] 02 62 23.53.57 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Thu 05/28/2015 07:12:32 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 09 01    LNK-ON (01)
Thu 05/28/2015 07:12:32 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Thu 05/28/2015 07:12:32 PM : [LNK-BGN     ] 02 64 01 00 06
Thu 05/28/2015 07:12:33 PM : [LNK-STAT    ] 02 53 M(01) gid=00 23.53.57 001D 42
Thu 05/28/2015 07:12:33 PM : [iNST-TX-I1  ] 02 62 23 53 57 0F 0D 00
Thu 05/28/2015 07:12:33 PM : [LNK-END     ] 02 65 06
Thu 05/28/2015 07:12:33 PM : [std MH      ] Unexpected Ack imCmd=65 cmd1= 0x57
Thu 05/28/2015 07:12:34 PM : [iNST-ACK    ] 02 62 23.53.57 0F 0D 00 06                 (00)
Thu 05/28/2015 07:12:34 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 0D 02           (02)
Thu 05/28/2015 07:12:34 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Thu 05/28/2015 07:12:38 PM : [iNST-TX-I1  ] 02 62 23 53 57 0F 0D 00
Thu 05/28/2015 07:12:38 PM : [iNST-ACK    ] 02 62 23.53.57 0F 0D 00 06                 (00)
Thu 05/28/2015 07:12:39 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 0D 02           (02)
Thu 05/28/2015 07:12:39 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Thu 05/28/2015 07:12:39 PM : [iNST-TX-I1  ] 02 62 23 53 57 0F 10 00
Thu 05/28/2015 07:12:39 PM : [iNST-ACK    ] 02 62 23.53.57 0F 10 00 06          ID-REQ (00)
Thu 05/28/2015 07:12:39 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 10 00    ID-REQ (00)
Thu 05/28/2015 07:12:39 PM : [iNST-SRX    ] 02 50 23.53.57 00.1D.42 8F 01 00           (00)
Thu 05/28/2015 07:12:39 PM : [std-Broadcast] 23.53.57-->00.1D.42, Max Hops=3, Hops Left=3
Thu 05/28/2015 07:12:39 PM : [23 53 57 0  ] Calibrating engine version
Thu 05/28/2015 07:12:39 PM : [iNST-TX-I2CS] 02 62 23 53 57 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Thu 05/28/2015 07:12:39 PM : [iNST-ACK    ] 02 62 23.53.57 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Thu 05/28/2015 07:12:40 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 2F 00           (00)
Thu 05/28/2015 07:12:40 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Thu 05/28/2015 07:12:40 PM : [iNST-ERX    ] 02 51 23 53 57 34 E9 19 15 2F 00 01 01 00 FF 00 A2 00 2B 96 A5 FF 1C 00 AD
Thu 05/28/2015 07:12:40 PM : [Ext-Direct  ] 23.53.57-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Thu 05/28/2015 07:12:40 PM : [23 53 57 0  ] Using Database Link Table offset 0x00F8 (reported 0x00F8)
Thu 05/28/2015 07:12:40 PM : [23 53 57 0  ] Failed to add device, reason 10
Thu 05/28/2015 07:12:41 PM : [All         ] Writing 0 bytes to devices
Edited by Brian H
If that is the case, it would be nice to see the same capability in the ISY.  I have had an access point lock up once or twice.  Would be nice to check them with the 3am query or other program  and fire off a notification if they fail to respond.  Otherwise there isn't much value to adding them to the device tree.
I have had two Hardware 2.5 Access Points with problems. Older hardware 1.? ones are on a different base board.
One just locked up and needed a power cycle.
The other one was dead. Power supply was around four volts on the unregulated 12 volts. Normally closer to 20 volts.
They are built on the same base 2413X PCB as the 2413S. Same capacitors issues as the hardware version 1.? 2413S  PLM's.
Did the capacitor change just like in my PLM and now both have been running again for over a month.
