Insteon 2635-222 - On/Off Module - 4 Tap Beacon Test
Has anyone successfully been able to complete the 4 tap beacon test with this 2635-222 On/Off Module?
Performing the 4 tap beacon tests results in nothing happening? The flow chart that is indicated in the full users manual makes no sense to me.
Anyone who has one can you describe in detail how this is completed.
Never mind, this one unit on hand requires Speedy Gonzalez to tap the set button 4 times super fast. Doing the same thing on three other units does not require lightning fast reflex's!
Knowledge keeps fingers fit B)
Its strange this single unit requires super fast tapping like - - - -. Whereas the other three simply need -  -  -  - ? Can anyone decipher the flow chart provided above to complete the same task???
