Is there a way to consolidate scenes?
Or is it normal to have a scene for each controller for the same responders? I do see that there are scenes that were built (automatically) that have multiple controllers. But I do not see how to add additional controllers myself.
Again, Thanks in advance for the replies. And again, pls see the attached.
Lp
You can Delete the one Scene that has duplicate Responders and add that Scene's Controller to another Scene. Insteon allows a node to be a Controller in one Scene only so the duplicate Responder Scene is Deleted first and then add the Controller to the other Scene.
Note that Controller1 will consider Controller2 a Responder and Controller2 will consider Controller1 a Responder.
It is normal to have multiple Controllers in the ISY Scene.
ISY Scene xxxx
Controller1
Controller2
Responder1
Responder2
Responder3
Edited by LeeG
