Accessing an old ISY26
How can I access an old ISY26 that was installed in 2007? This home has about 60 Insteon switches and plug-in modules and has been working great. The customer has sold his home and would like to disable the personalized programming. Is there a version of the Admin program that will still talk to the ISY26? Also, Can I upgrade the ISY26 to an ISY994i without loosing the link to all of the already installed modules?
Scenes are written to the devices themselves, programs are written to the ISY, so removing the ISY disables the programming without affecting anything else.
Yes, you can use an ISY26. Release 3.3.10 is the latest revision for the ISY 26. Not all new devices are supported.
Yes, you can migrate from the ISY26 to a ISY994i without losing links, But, if the ISY26 is powered from the PLM (2412), then the migration may be more involved.
Stusviews, Thanks for the prompt reply. I will give that a try and let you know. If I remember correctly, I think the P{LM may be the 2412.
Larry
