AT&T to end email-to-text ×
Cannot communicate error pop up with Outdoor ApplianceLinc 2456SE
I have two ApplianceLinc Outdoor Plugin Modules (2456SE) v.41.  When send any On or Off command the device changes state, but the ISY generates a "Failed Communicating With" dialog.  It says Cannot Communicate With xxxxx.  Please check connections.  The device then has a red "!" next to it.  If I query the device, the correct status is returned and the error condition is cleared. I am using the latest released ISY firmware v.4.2.30 on an ISY 994i/IR PRO.  Any ideas on how to solve this problem?
Bill
Run Tools | Diagnostics | Event Viewer at LEVEL 3.   Send a few On and Off commands and post the event trace.
Is there a load plugged into ApplianceLinc?  It can signal an error if there is no load.
If it's powering low voltage yard lighting, that's likely the culprit.
I had to put a filterlinc on one of mine to get it to work
It is load related.  I wonder why that is.  I am in testing mode and didn't have a load attached.  I use these for Holiday lighting.  My indoor appliance links do not have the same problem though.  Here is the log.  One has a load and work properly and the other had no load and it errors out.  Why is this?
insteon log 2.txt
Different firmware levels/types of devices have different responses.   This Outdoor ApplianceLinc NAKs the request when there is no load attached.
Fri 08/07/2015 01:52:56 PM : [iNST-TX-I1  ] 02 62 14 ED F5 0F 11 FF
Fri 08/07/2015 01:52:56 PM : [iNST-ACK    ] 02 62 14.ED.F5 0F 11 FF 06          LTONRR (FF)
Fri 08/07/2015 01:52:56 PM : [iNST-SRX    ] 02 50 14.ED.F5 34.E7.B7 AB 11 FE    LTONRR (FE)
Fri 08/07/2015 01:52:56 PM : [Std-Direct Nack] 14.ED.F5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
The AB is a NAK, the FE indicates "no load found".
EDIT:  this is a feature of the Outdoor ApplianceLinc rather than a problem.   It lets you know that the load being controlled cannot be found by the device.   An outdoor module could have buried cable that is not reaching the load even though the cable is plugged into the device.
No option in the Developer Notes to turn Off that type of NAK.  The node can be Disabled in the ISY so that Direct On/Off commands are not issued by the ISY.  Disable does not affect use of device in a Scene.
      37.7k
      376.6k
