Leak sensors
Hi
after having some trouble somewhere in my system, 2 leak detectors are not communicating with my ISY, how do you get them to work again ? also I by mistake did a restore on them and they have the icon next to them that reads (1011) how do you get rid of that any help would be great, do I have to hit the button on the top ? one is under my dishwasher and hard to get at
Thanks Jeff
Battery operated Insteon modules go into a power saving mode and have to be woken up before you can write to them.
Yes Hold the Set Button until the LED starts flashing. Then you should be able to write updated to it.
Hi
Thanks Jeff
Hello Jeff,
If the icon reads 1011 simply press one Leak Sensor until it goes into linking mode. Then right click and select write updates on that node. Once complete do the same to the other Leak Sensor.
NOTE: You must press the Leak Sensor set button twice to take it out of linking mode.
Hold the button down on the top for a bit until linking mode is entered and then do a restore.
They should update ISY once the heartbeat happens again. If you didn't have them in linking mode they should be OK but....
Hi
Thanks for all the help I will try you guys suggestions , I'm not sure whats going on but I got a new desk top. (new to me) late 2012 IMac every thing was great, but a few days ago trying to sign on to the admin console and it said ISY not found I messed around trying to get it to work, rebooted my computer, the ISY, my modem try getting into to from my wifes laptop macbook, and it worked, tried my desktop and got on it worked for a few days. Now I can't get into the admin console again from my desktop. we have different OS and java , mine is newer, yosemite and java V8 update 60. any thing I can do
You guys are always a great help
Thanks, Jeff
      37.3k
      373.4k
