Admin console when away from home
I have always used the admin console to make changes to programs while at home using my home network.
I'm now using a Surface 3 tablet to access the admin console (via java applet) and would like to use it away from home.  What is the best way to access the admin console when away from home and on a different network?
Thanks in advance!
I just got a surface 3 yesterday, partially for remote admin console access! Here are a couple ways
1) VPN. VPN software lets you access your LAN like you were there. The surface has a VPN client built in, or there are other clients like openvpn. On your house side, you need a VPN server. My router provides that. If your router has A VPN server, that would work. A VPN allows you to access other things on your LAN in addition to the ISY
2) Port forwarding. Use your router's features to redirect an SSL port to your ISY. Set an option up in ISY Finder with your house's IP address and the port number that redirects to your ISY. A little bit of technical knowledge is needed to do this, we can help with that here if needed
3) The new ISY portal. Its in beta, but once available, it is designed specifically to put your ISY on the internet securely, and for you to access it remotely.
If you can wait, and don't need to access other devices on your LAN, probably #3 is best
If you can't wait, its a toss up between the other two options...  Does your router have VPN and do you need to work with other devices? Then #1. If not, probably #2
Paul
Edited by paulbates
I'll add #4: If you subscribe to Mobilinc Connect you can use that service as well to run the admin console.
Michael.
Michael.
I do subscribe to Mobilinc Connect.  With that on my Windows 10 Surface 3 PC, will I be able to make program changes in the Admin Console?  Is it a Windows 10 app?  Thanks!
It uses Java - just like when you are local. It's the full admin app, so yes - you can make any change that you can make locally.
I believe you lookup the URL to use within the Mobilinc app itself if you are using the Mobilinc Connect profile. It incorporates the ISY uuid, and you authenticate with your Mobilinc Connect credential instead of your ISY credential.
That works at home....I'll need to test it outside my home network.  I'll let you know if I have any problems.
  • 10 months later...
Ok guys long time lurker, first time poster-  finally got my system up and going. One major issue at this moment is that I cannot seem to access my Admin console from outside my network. I am running a Netgear R7800 router that has Unpnp but for some reason did not work when I tried to set my ISY for remote access. But I just went ahead and port forwarded port 443 and reserved the IP. I can use the App CtrlHome on my Iphone and access my ISY remotely on my desktop, but when I select admin console it goes there, shows the screen and then times out. So I figured I had to install the applet. I also cleared everything in the Java cache. So I installed the one that matches my firmware 4.5.1. Which brings up the ISY finder but I have tried
https://myIp
http://myip
https://myip:443
http://myip:443
But keeps saying not found, what am I missing? Thanks
You can't use your LAN IP to access the ISY from off-site. You need to use your WAN IP. And you do need to suffix the port, as you've shown.
Thanks for the fast reply-Sorry I might not have posted it correctly but I am using the one that I use to access my router from outside my network WAN. The same one that I use for the Ctrlhome app.
Use this tool to verify that the port is open.
I tried using that tool earlier but for some reason it would not let me enter(change) the IP but found another one (yougetsignal) and it says that it is open.
What's the result if you try an non-secure port as a test?
What do you mean no secure port? Something like port 80? If that is the case it says its closed
No, I mean using an HTTP port as opposed to an HTTPS port.
Well I tried something I should have tried first, tried logging in from another network and it works just fine...Must be something with my network at work that does not allow it. Too bad I was really looking forward to wasting my time at work to write some programs. But it did pop up a message about my certificate is unsafe etc, and send me to the Network security Manual. But is that just for the Pro? I have the 994i with Z-wave. Should I be doing anything different regarding the security setup? Thanks
