Do you need a power supply?
Hi gang,
This may be my craziest Newbie question yet ...
My ISY 99i Pro is not plugged in to power, only the two ethernet cables, yet it runs. I noticed this today. It seems to run without being hooked to a power supply, but the owner's manual states that it is supposed to be plugged in. My unit came in a tiny box which didn't contain a power supply. However, there is a power in jack on the back of the unit ...
Is this thing supposed to be plugged into a power adaptor as well as the ethernet cables to the PLM and to the switch?
Cheers!
The ISY-99 is powered from the PLM but may be powered with a separate supply. The ISY-26 needed a separate power supply.
Rand
