MobiLinc (Android) 2.0.7 now supports Variables!
Hi Folks,
We just released MobiLinc (Android) 2.0.7 to Google Play and our own key licensed users. 2.0.7 now includes Integer and Variable support under the "Programs" section of MobiLinc.
To set the Value or Initial Value of the Integer or Variable, tap the row to set.
The update is immediately available to our license key users by opening up MobiLinc and going to My Settings->Check for Updates.
For Google Play users, the update will roll out via the Google Play servers over the next 24 hours.
Wes
Thank you,
     thank you!!
Requesting some more icons
      Battery with normal and discharged slash out
      Pump... Well and/or sump style
      Ventilation fan icon got changed?
      Heartbeat icon
Will this be available for BB10 as well, or can a switch for a license key?
Woot! Thank you. Now to plugins I guess (Elk/Cameras).... I really miss not being able to watch a camera and control devices in the proximity - especially the garage door.
Michael.
Just updated and now receiving a sync error! It is saying that it is unable to connect to my ISY. Any assistance is greatly appreciated.
Robert
Robert
Did you try resyncing your ISY under the settings menu? You may have made changes to programs, scenes and/or variables since the last sync.
Yes I did. I even tried restarting everything. But it will not sync up.
Robert
You have a Samsung Android phone?
Turn off the WiFi or the autoswitch option under WiFi config.. Most apps start deciding to use WiFi or mobile. If  things change they can't follow or if they detect WiFi is On  they assume you are at home and use that IP address.
Hi Robert,
Connection errors almost always means there's a mismatch in your settings somewhere. If you are unable to figure it out, please send me the following to support@mobilinc.com:
- Admin Console->Configuration Tab.
- Screenshot of your MobiLinc->My Settings->Lighting Controller page.
- Screenshot of your router's port forward page (if not using MobiLinc Connect).
- The results of going to: https://www.google.com/webhp?hl=en#hl=en&q=what+is+my+ip(if not using MobiLinc Connect)
Wes
io_guy,
Please send me your BB10 email receipt to support@mobilinc.com and we'll see what we can do.
Wes
Wes
Is this the only way to update on BB10?
just got the update and resynched - looks good!  This functionality is huge for me - thanks Wes, keep it up!
Hi Wes,
Sorry for the late reply. I was out of town and couldn't respond back. But I was able to sync it once I left my home and turned off my wifi. Not sure why it wouldn't sync at home. Thank you for the assistance as I greatly appreciate it.
Robert
Updated to 2.0.7. I use secure connections and manual port forwarding in my setup (not "Connect"). I was unable to sync with the update. The fix was to specify the ISY port (LAN side) in my port-forward setup in my router. Previously, the port on the WAN side (incoming) would pass through unchanged to the LAN, if the port on the LAN side was blank/not specified.
Additionally, due to my employers "autolock of the smartphone" when the screen turns off, I had to keep the screen lit up while the Sync was happening. If I let the phone lock, the sync failed. Android OS (Samsung S6 Edge).
Works now!
Note: Admittedly the port issue could have been a change in the router firmware, as both MobiLink and the router firmware were updated in the last 10 days.
Missed that update almost 3 weeks ago, but my phone did not.  I was able to see my variables which is huge.  NOW maybe I can figure out why the lights go out when I know I walked by the motion sensors!
  • 1 month later...
Thank you,
     thank you!!
      Heartbeat icon
I second this, but my wishlist goes on and on and on. The sad thing is, many of my wishes are already fulfilled on iOS.
I did the five day trial of Mobilinc, and was less than impressed. It would be one thing if the software as a whole was in the development process, but I've seen the iOS version, and it feels as though Android is neglected. To add insult to injury, its the same price.
The five-day trial counter should reset for each new update. I like the way this software is shaping up, but when it comes to spending money on this software (well above the price of the average android app), I would have to see drastic improvement, which I never will, because my trial has expired.
I've started developing my own app through Tasker and found it to be not too difficult. It is meeting my needs for now.
Do you guys have any roadmap on how you plan to improve the release schedule of the android fork of this software?
Edited by Pacificwing
Hi Pacificwing,
With each new version the trial period is reset to another 5 days.
Yes, but it's internal only. We can't comment publicly on possible future features or releases.
Wes
Edited by InsteonNut
  • 5 months later...
It is about time to bring the Android App in par with the iOS one.. It is very sad that it is way behind as of right now!
Cheers,
Alex
