Interface with Amazon Echo?
awzulich
Still no success setting a thermostat even though I change the name from Main Thermostat to Main Weather. Alexa seems to recognize that it's a thermostat, the reply is always, "Set thermostat mode for which device?"
To set a thermostat setpoint, try one of the following utterances (Just ignore the leading SetThermostatSetpoint, which is the intent name):
SetThermostatSetpoint set {device} {mode} setpoint to {degrees}
SetThermostatSetpoint set {device} thermostat {mode} setpoint to {degrees}
SetThermostatSetpoint set {device} {mode} setpoint to {degrees} degrees
SetThermostatSetpoint set {device} thermostat {mode} setpoint to {degrees} degrees
SetThermostatSetpoint set {device} {mode} temperature to {degrees}
SetThermostatSetpoint set {device} thermostat {mode} temperature to {degrees}
SetThermostatSetpoint set {device} {mode} temperature to {degrees} degrees
SetThermostatSetpoint set {device} thermostat {mode} temperature to {degrees} degrees
SetThermostatSetpoint change {device} {mode} setpoint to {degrees}
SetThermostatSetpoint change {device} thermostat {mode} setpoint to {degrees}
SetThermostatSetpoint change {device} {mode} setpoint to {degrees} degrees
SetThermostatSetpoint change {device} thermostat {mode} setpoint to {degrees} degrees
SetThermostatSetpoint change {device} {mode} temperature to {degrees}
SetThermostatSetpoint change {device} thermostat {mode} temperature to {degrees}
SetThermostatSetpoint change {device} {mode} temperature to {degrees} degrees
SetThermostatSetpoint change {device} thermostat {mode} temperature to {degrees} degrees
SetThermostatSetpoint set {mode} setpoint to {degrees}
SetThermostatSetpoint set thermostat {mode} setpoint to {degrees}
SetThermostatSetpoint set {mode} setpoint to {degrees} degrees
SetThermostatSetpoint set {mode} temperature to {degrees}
SetThermostatSetpoint set thermostat {mode} temperature to {degrees}
SetThermostatSetpoint set {mode} temperature to {degrees} degrees
SetThermostatSetpoint set thermostat {mode} temperature to {degrees} degrees
SetThermostatSetpoint change {mode} setpoint to {degrees}
SetThermostatSetpoint change thermostat {mode} setpoint to {degrees}
SetThermostatSetpoint change {mode} setpoint to {degrees} degrees
SetThermostatSetpoint change thermostat {mode} setpoint to {degrees} degrees
SetThermostatSetpoint change {mode} temperature to {degrees}
SetThermostatSetpoint change thermostat {mode} temperature to {degrees}
SetThermostatSetpoint change {mode} temperature to {degrees} degrees
SetThermostatSetpoint change thermostat {mode} temperature to {degrees} degrees
SetThermostatSetpoint set {device} setpoint to {degrees}
SetThermostatSetpoint set {device} thermostat setpoint to {degrees}
SetThermostatSetpoint set {device} setpoint to {degrees} degrees
SetThermostatSetpoint set {device} thermostat setpoint to {degrees} degrees
SetThermostatSetpoint set {device} temperature to {degrees}
SetThermostatSetpoint set {device} thermostat temperature to {degrees}
SetThermostatSetpoint set {device} temperature to {degrees} degrees
SetThermostatSetpoint set {device} thermostat temperature to {degrees} degrees
SetThermostatSetpoint change {device} setpoint to {degrees}
SetThermostatSetpoint change {device} thermostat setpoint to {degrees}
SetThermostatSetpoint change {device} setpoint to {degrees} degrees
SetThermostatSetpoint change {device} thermostat setpoint to {degrees} degrees
SetThermostatSetpoint change {device} temperature to {degrees}
SetThermostatSetpoint change {device} thermostat temperature to {degrees}
SetThermostatSetpoint change {device} temperature to {degrees} degrees
SetThermostatSetpoint change {device} thermostat temperature to {degrees} degrees
SetThermostatSetpoint set {device} to {degrees}
SetThermostatSetpoint set {device} thermostat to {degrees}
SetThermostatSetpoint set {device} to {degrees} degrees
SetThermostatSetpoint set {device} thermostat to {degrees} degrees
SetThermostatSetpoint change {device} to {degrees}
SetThermostatSetpoint change {device} thermostat to {degrees}
SetThermostatSetpoint change {device} to {degrees} degrees
SetThermostatSetpoint change {device} thermostat to {degrees} degrees
SetThermostatSetpoint change setpoint for {device}
SetThermostatSetpoint change thermostat setpoint for {device}
SetThermostatSetpoint set thermostat setpoint to {degrees}
SetThermostatSetpoint set thermostat setpoint to {degrees} degrees
SetThermostatSetpoint set temperature to {degrees}
SetThermostatSetpoint set thermostat temperature to {degrees}
SetThermostatSetpoint set temperature to {degrees} degrees
SetThermostatSetpoint set thermostat temperature to {degrees} degrees
SetThermostatSetpoint change setpoint to {degrees}
SetThermostatSetpoint change thermostat setpoint to {degrees}
SetThermostatSetpoint change setpoint to {degrees} degrees
SetThermostatSetpoint change thermostat setpoint to {degrees} degrees
SetThermostatSetpoint change temperature to {degrees}
SetThermostatSetpoint change thermostat temperature to {degrees}
SetThermostatSetpoint change temperature to {degrees} degrees
SetThermostatSetpoint change thermostat temperature to {degrees} degrees
SetThermostatSetpoint set thermostat to {degrees}
SetThermostatSetpoint set thermostat to {degrees} degrees
SetThermostatSetpoint change thermostat to {degrees}
SetThermostatSetpoint change thermostat to {degrees} degrees
I tried a few commands (without SetThermostaSetpoint) and each time I got the local weather. When I used SetThermostaSetpoint, I got the weather in Augusta, Maine (the thermostat is called Main Weather). I'' try another name B)
BTW, refreshing devices is a PITA. The last time Alexa asked if I want to wait 31 times (sometimes it takes only 4-5 waits).
You need to say "Alexa, tell izzy to <then the command>
Alternatively, you could say "open izzy", then say the command while it is listening. But you have to wait for welcome prompt to finish.
Otherwise, the skill is not invoked.
The refresh can be long, I know. This is due to the fact that it has retrieve the spoken field for each and every devices that you have.
The skill starts by retrieving your list of devices with GET /rest/nodes
Then for every devices, it check if you have a spoken word using GET /rest/nodes/<address>/note
The more devices there are, the more requests there are. Hopefully it will be possible to retrieve it from ISY in a single request, but this is not possible today.
Benoit.
Minor success. I used SetThermostatSetpoint first, named the device (now called Heater) and requested 80º. Alexa asked "Which device?" then, "Which mode?" and finally replied "heater heating setpoint is now set to 80 degrees." The thermostat set point was set to 40º.
I reset the thermostat to 75º and repeated the commands. Same result, the thermostat was set to 40º.
Update: Me: "Tell Izzy to set heater heating to 80º." Alexa: "heater temperature is 75.50. It is set to heat at 304 degrees." Set point is unchanged.
Edited by stusviews
I purchased the ISY portal so I could use my new Echo and my Mobilinc portal quit working.  Surely I do not have to choose between the two...
Jay
Sorry, but that is no help in answering the question. It just opens up a purchase page. I am following the thread as I contemplate buying an Echo, but do bot want to lose Mobilinc either. Can someone enlighten us, please, on the question of using both Mobilinc and Echo, and the effects of this?
You don't need Mobilinc Connect but can connect directly with ISY...  I've heard something about getting Mobilinc Connect integrated with the ISY Portal but don't know what's become of it.
Jon...
Edited by jerlands
Jon...
Thank you, Jon. So, if I buy an Echo to play around with, is it safe to say I will RETAIN my Mobilinc functionality? I use Mobilinc all the time, and need it far more than Echo capability.
Yes... I connect my android (galaxy S4) running Mobilinc directly to ISY via DDNS but have never used Mobilinc Connect.
Jon...
Madcodger,
Currently you CANNOT utilize more than one portal at a time. So it's either ML Connect or the ISY portal. I had the ML Connect portal installed prior to installing the ISY portal. As soon as I installed the ISY portal, the ML Connect portal disappeared.
Best of luck,
Chuck
I am still seeing the same problem as the other day.  If I tell ALexa to open Izzy I get the greeting.  Then one command works.  Nothing else works until I tell Alexa to open Izzy again.  It seems that after one command the skill closes and I have to re-open it.
Hello Digger,
There are several ways to invoke a skill
You can say "Alexa, open izzy", then she will listen to your command, then close. If
It is preferable to invoke the skill with a one shot command this way:
"Alexa, tell izzy to <then your command"
"Alexa, ask izzy to <then your command"
"Alexa, ask izzy about <then your command"
Benoit.
Hello Digger,
Benoit.
I am doing that. It doesn't work. I have to open the skill and hear the greeting before it will work.
"Alexa tell Izzy switch entrance on" does not work. "Alexa open Izzy". Greeting plays. "Alexa tell Izzy switch entrance on" and she responds turning on Entrance. Then "Alexa tell Izzy switch entrance off" does not work until I say "Alexa open Izzy" and it's rinse and repeat.
Faster/easier to use the wall switch
I looked at the log and spotted this request,
2015-12-12, 22:04:08 - info: Voice degree response for a3658851-c517-4de9-8865-bdbce5c5ba44: 80
2015-12-12, 22:04:08 - info: Voice cmd: a3658851-c517-4de9-8865-bdbce5c5ba44 Set thermostat heater setpoint for heating mode to 80 degrees
2015-12-12, 22:04:08 - info: Server req. REQUEST /rest/nodes/1D%206E%20F8%201/cmd/CLISPH/80
2015-12-12, 22:04:09 - info: Server req. 200 Client data END for /rest/nodes/1D%206E%20F8%201/cmd/CLISPH/80
It sent the intended setpoint.
However, I remember that some thermostat uses values in increments of .5. I had implemented this in HAD a while back.
I will fix this.
Benoit.
You need to say: "Alexa, tell izzy to <your command>"
The to is important. Otherwise, the skill is not invoked.
Benoit.
Benoit.
Thanks Benoit... I was having the same problem.
Jon...
Benoit,
Is it possible to post the entire utterance list for all devices? It might help in figuring out how to speak to Izzy.
Ron
This is the complete list of utterances (You have to ignore the first word):
RefreshDevices refresh devices
RefreshDevices refresh the devices
RefreshDevices refresh my devices
SelectISY choose {isy}
SelectISY select {isy}
SelectISY switch to {isy}
SelectISY set my preferred i. s. y. to {isy}
SelectISY change my preferred i. s. y. to {isy}
SelectISY switch my preferred i. s. y. to {isy}
SelectISY switch i. s. y.
SelectISY switch my i. s. y.
SelectISY switch to new i. s. y.
SelectISY change i. s. y.
SelectISY change my i. s. y.
SelectISY select i. s. y.
SelectISY select my i. s. y.
SelectISY select new i. s. y.
SelectISY choose i. s. y.
SelectISY choose my i. s. y.
SelectISY choose new i. s. y.
SelectISY set my preferred izzy to {isy}
SelectISY change my preferred izzy to {isy}
SelectISY switch my preferred izzy to {isy}
SelectISY switch izzy
SelectISY switch my izzy
SelectISY switch to new izzy
SelectISY change izzy
SelectISY change my izzy
SelectISY select izzy
SelectISY select my izzy
SelectISY select new izzy
SelectISY choose izzy
SelectISY choose my izzy
SelectISY choose new izzy
GetISY what's my i. s. y.
GetISY what is my i. s. y.
GetISY get my current i. s. y.
GetISY my current i. s. y.
GetISY what's my current i. s. y.
GetISY what is my current i. s. y.
GetISY give me my current i. s. y.
GetISY tell me my current i. s. y.
GetISY get my selected i. s. y.
GetISY my selected i. s. y.
GetISY what's my selected i. s. y.
GetISY what is my selected i. s. y.
GetISY give me my selected i. s. y.
GetISY tell me my selected i. s. y.
GetISY get my preferred i. s. y.
GetISY my preferred i. s. y.
GetISY what's my preferred i. s. y.
GetISY what is my preferred i. s. y.
GetISY give me my preferred i. s. y.
GetISY tell me my preferred i. s. y.
GetISY what i. s. y. am i using
GetISY which i. s. y. am i using
GetISY what i. s. y. am i controlling
GetISY which i. s. y. am i controlling
GetISY what i. s. y. is selected
GetISY which i. s. y. is selected
GetISY what's my izzy
GetISY what is my izzy
GetISY get my current izzy
GetISY my current izzy
GetISY what's my current izzy
GetISY what is my current izzy
GetISY give me my current izzy
GetISY tell me my current izzy
GetISY get my selected izzy
GetISY my selected izzy
GetISY what's my selected izzy
GetISY what is my selected izzy
GetISY give me my selected izzy
GetISY tell me my selected izzy
GetISY get my preferred izzy
GetISY my preferred izzy
GetISY what's my preferred izzy
GetISY what is my preferred izzy
GetISY give me my preferred izzy
GetISY tell me my preferred izzy
GetISY what izzy am i using
GetISY which izzy am i using
GetISY what izzy am i controlling
GetISY which izzy am i controlling
GetISY what izzy is selected
GetISY which izzy is selected
GetStatus get status of {device}
GetStatus get status for {device}
GetStatus get the status of {device}
GetStatus get the status for {device}
GetStatus the status of {device}
GetStatus the status for {device}
GetStatus status of {device}
GetStatus status for {device}
GetStatus what's the status of {device}
GetStatus what's the status for {device}
GetStatus what is the status of {device}
GetStatus what is the status for {device}
GetStatus give me the status of {device}
GetStatus give me the status for {device}
GetStatus tell me the status of {device}
GetStatus tell me the status for {device}
GetStatus tell me if {device} is locked
GetStatus tell me if {device} is unlocked
GetStatus if {device} is locked
GetStatus if {device} is unlocked
GetStatus if {device} is turned on
GetStatus if {device} is turned off
GetStatus what is {device} set to
GetStatus what's {device} set to
GetStatus get what {device} is set to
GetStatus give me what {device} is set to
GetStatus tell me what {device} is set to
GetStatus what is the {device} set to
GetStatus what's the {device} set to
GetStatus get what the {device} is set to
GetStatus give me what the {device} is set to
GetStatus tell me what the {device} is set to
GetStatus what is the {device} brightness level
GetStatus what's the {device} brightness level
GetStatus get the {device} brightness level
GetStatus get {device} brightness level
GetStatus give me the {device} brightness level
GetStatus give me {device} brightness level
GetStatus what is the {device} level
GetStatus what's the {device} level
GetStatus get the {device} level
GetStatus get {device} level
GetStatus give me the {device} level
GetStatus give me {device} level
GetStatus what is the {device} light level
GetStatus what's the {device} light level
GetStatus get the {device} light level
GetStatus get {device} light level
GetStatus give me the {device} light level
GetStatus give me {device} light level
GetStatus what is my {device} set to
GetStatus what's my {device} set to
GetStatus get what my {device} is set to
GetStatus give me what my {device} is set to
GetStatus tell me what my {device} is set to
GetStatus get my {device} brightness
GetStatus give me my {device} brightness
GetStatus get my {device} level
GetStatus give me my {device} level
GetStatus what is my {device} light level
GetStatus what's my {device} light level
GetStatus get my {device} light level
GetStatus give me my {device} light level
GetStatus what is the brightness level of {device}
GetStatus what's the brightness level of {device}
GetStatus get the brightness level of {device}
GetStatus give me the brightness level of {device}
GetStatus what is the brightness of {device}
GetStatus what's the brightness of {device}
GetStatus get the brightness of {device}
GetStatus give me the brightness of {device}
GetStatus what is the level of {device}
GetStatus what's the level of {device}
GetStatus get the level of {device}
GetStatus give me the level of {device}
GetStatus what is the light level of {device}
GetStatus what's the light level of {device}
GetStatus get the light level of {device}
GetStatus give me the light level of {device}
GetStatus what is it set to
GetStatus get what it is set to
GetStatus give me what it is set to
GetStatus tell me what it is set to
TurnOn turn on {device} to {percent} percent
TurnOn turn on {device} {percent} percent
TurnOn switch on {device} to {percent} percent
TurnOn switch on {device} {percent} percent
TurnOn light up {device} to {percent} percent
TurnOn light up {device} {percent} percent
TurnOn turn {device} on
TurnOn switch {device} on
TurnOn open {device}
TurnOn turn on
TurnOn switch on
TurnOn light up
TurnOn light
TurnOn open
TurnOff turn off {device}
TurnOff switch off {device}
TurnOff shut off {device}
TurnOff shut up {device}
TurnOff turn {device} off
TurnOff switch {device} off
TurnOff shut {device} off
TurnOff close {device}
TurnOff turn off
TurnOff switch off
TurnOff shut up
TurnOff shut
TurnOff close
Brighten brighten {device}
Brighten brighten up {device}
Brighten brighten {device} up
Brighten lighten {device}
Brighten lighten up {device}
Brighten lighten {device} up
Brighten pick up {device}
Brighten turn up {device}
Brighten turn {device} up
Brighten make {device} brighter
Brighten make {device} lighter
Brighten brighten {device} a {magnitude}
Brighten brighten up {device} a {magnitude}
Brighten brighten {device} up a {magnitude}
Brighten lighten {device} a {magnitude}
Brighten lighten up {device} a {magnitude}
Brighten lighten {device} up a {magnitude}
Brighten pick up {device} a {magnitude}
Brighten pick {device} up a {magnitude}
Brighten turn up {device} a {magnitude}
Brighten turn {device} up a {magnitude}
Brighten make {device} brighter a {magnitude}
Brighten make {device} lighter a {magnitude}
Brighten brighten {device} more
Brighten brighten up {device} more
Brighten lighten {device} more
Brighten lighten up {device} more
Brighten pick up {device} more
Brighten turn up {device} more
Brighten brighten {device} a {magnitude} more
Brighten brighten up {device} a {magnitude} more
Brighten brighten {device} up a {magnitude} more
Brighten lighten {device} a {magnitude} more
Brighten lighten up {device} a {magnitude} more
Brighten lighten {device} up a {magnitude} more
Brighten pick up {device} a {magnitude} more
Brighten pick {device} up a {magnitude} more
Brighten turn up {device} a {magnitude} more
Brighten turn {device} up a {magnitude} more
Brighten make {device} brighter a {magnitude} more
Brighten make {device} lighter a {magnitude} more
Brighten brighten a {magnitude}
Brighten lighten a {magnitude}
Brighten pick up a {magnitude}
Brighten turn up a {magnitude}
Brighten brighten a {magnitude} more
Brighten lighten a {magnitude} more
Brighten pickup a {magnitude} more
Brighten turn up a {magnitude} more
Dim dim {device}
Dim darken {device}
Dim fade {device}
Dim turn down {device}
Dim make {device} darker
Dim dim {device} a {magnitude}
Dim darken {device} a {magnitude}
Dim fade {device} a {magnitude}
Dim turn down {device} a {magnitude}
Dim make {device} darker a {magnitude}
Dim dim {device} a {magnitude} more
Dim darken {device} a {magnitude} more
Dim fade {device} a {magnitude} more
Dim turn down {device} a {magnitude} more
Dim make {device} darker a {magnitude} more
Dim dim a {magnitude}
Dim darken a {magnitude}
Dim fade a {magnitude}
Dim turn down a {magnitude}
Dim dim a {magnitude} more
Dim darken a {magnitude} more
Dim fade a {magnitude} more
Dim turn down a {magnitude} more
Dim dim
Dim darken
Dim fade
Dim turn down
Toggle toggle {device}
Toggle toggle
Lock lock {device}
Lock secure {device}
Lock lock
Lock secure
Unlock unlock {device}
Unlock unlock
LockAll lock all doors
LockAll lock all the doors
LockAll lock everything
LockAll lock every door
LockAll lock every doors
LockAll secure all the doors
LockAll secure all doors
LockAll secure house
LockAll secure home
UnlockAll unlock all doors
UnlockAll unlock all the doors
UnlockAll unlock everything
UnlockAll unlock every door
UnlockAll unlock every doors
GetThermostatMode get the thermostat mode for {device}
GetThermostatMode get thermostat mode for {device}
GetThermostatMode the thermostat mode for {device}
GetThermostatMode thermostat mode for {device}
GetThermostatMode what's the thermostat mode for {device}
GetThermostatMode what is the thermostat mode for {device}
GetThermostatMode give me the thermostat mode for {device}
GetThermostatMode tell me the thermostat mode for {device}
GetThermostatMode get the mode for {device} thermostat
GetThermostatMode get mode for {device} thermostat
GetThermostatMode the thermostat mode for {device} thermostat
GetThermostatMode mode for {device} thermostat
GetThermostatMode what's the mode for {device} thermostat
GetThermostatMode what is the mode for {device} thermostat
GetThermostatMode give me the mode for {device} thermostat
GetThermostatMode tell me the mode for {device} thermostat
GetThermostatMode get the mode of {device} thermostat
GetThermostatMode get mode of {device} thermostat
GetThermostatMode the thermostat mode of {device} thermostat
GetThermostatMode mode of {device} thermostat
GetThermostatMode what's the mode of {device} thermostat
GetThermostatMode what is the mode of {device} thermostat
GetThermostatMode give me the mode of {device} thermostat
GetThermostatMode tell me the mode of {device} thermostat
GetThermostatMode {device} mode
GetThermostatMode the thermostat thermostat mode
GetThermostatTemp what's the temperature of {device} thermostat
GetThermostatTemp get the thermostat temperature for {device}
GetThermostatTemp get thermostat temperature for {device}
GetThermostatTemp the thermostat temperature for {device}
GetThermostatTemp thermostat temperature for {device}
GetThermostatTemp what's the thermostat temperature for {device}
GetThermostatTemp what is the thermostat temperature for {device}
GetThermostatTemp give me the thermostat temperature for {device}
GetThermostatTemp tell me the thermostat temperature for {device}
GetThermostatTemp get the temperature for {device} thermostat
GetThermostatTemp get temperature for {device} thermostat
GetThermostatTemp the thermostat temperature for {device} thermostat
GetThermostatTemp temperature for {device} thermostat
GetThermostatTemp what's the temperature for {device} thermostat
GetThermostatTemp what is the temperature for {device} thermostat
GetThermostatTemp give me the temperature for {device} thermostat
GetThermostatTemp tell me the temperature for {device} thermostat
GetThermostatTemp get the temperature of {device} thermostat
GetThermostatTemp get temperature of {device} thermostat
GetThermostatTemp the thermostat temperature of {device} thermostat
GetThermostatTemp temperature of {device} thermostat
GetThermostatTemp what is the temperature of {device} thermostat
GetThermostatTemp give me the temperature of {device} thermostat
GetThermostatTemp tell me the temperature of {device} thermostat
GetThermostatTemp {device} temperature
GetThermostatTemp {device} thermostat
GetThermostatTemp the thermostat thermostat temperature
GetThermostatTemp get the thermostat temp for {device}
GetThermostatTemp get thermostat temp for {device}
GetThermostatTemp the thermostat temp for {device}
GetThermostatTemp thermostat temp for {device}
GetThermostatTemp what's the thermostat temp for {device}
GetThermostatTemp what is the thermostat temp for {device}
GetThermostatTemp give me the thermostat temp for {device}
GetThermostatTemp tell me the thermostat temp for {device}
GetThermostatTemp get the temp for {device} thermostat
GetThermostatTemp get temp for {device} thermostat
GetThermostatTemp the thermostat temp for {device} thermostat
GetThermostatTemp temp for {device} thermostat
GetThermostatTemp what's the temp for {device} thermostat
GetThermostatTemp what is the temp for {device} thermostat
GetThermostatTemp give me the temp for {device} thermostat
GetThermostatTemp tell me the temp for {device} thermostat
GetThermostatTemp get the temp of {device} thermostat
GetThermostatTemp get temp of {device} thermostat
GetThermostatTemp the thermostat temp of {device} thermostat
GetThermostatTemp temp of {device} thermostat
GetThermostatTemp what's the temp of {device} thermostat
GetThermostatTemp what is the temp of {device} thermostat
GetThermostatTemp give me the temp of {device} thermostat
GetThermostatTemp tell me the temp of {device} thermostat
GetThermostatSetpoint get the thermostat setpoint for {device}
GetThermostatSetpoint get thermostat setpoint for {device}
GetThermostatSetpoint the thermostat setpoint for {device}
GetThermostatSetpoint thermostat setpoint for {device}
GetThermostatSetpoint what's the thermostat setpoint for {device}
GetThermostatSetpoint what is the thermostat setpoint for {device}
GetThermostatSetpoint give me the thermostat setpoint for {device}
GetThermostatSetpoint tell me the thermostat setpoint for {device}
GetThermostatSetpoint get the setpoint for {device} thermostat
GetThermostatSetpoint get setpoint for {device} thermostat
GetThermostatSetpoint setpoint for {device} thermostat
GetThermostatSetpoint what's the setpoint for {device} thermostat
GetThermostatSetpoint what is the setpoint for {device} thermostat
GetThermostatSetpoint give me the setpoint for {device} thermostat
GetThermostatSetpoint tell me the setpoint for {device} thermostat
GetThermostatSetpoint get the setpoint of {device} thermostat
GetThermostatSetpoint get setpoint of {device} thermostat
GetThermostatSetpoint the thermostat setpoint of {device} thermostat
GetThermostatSetpoint setpoint of {device} thermostat
GetThermostatSetpoint what's the setpoint of {device} thermostat
GetThermostatSetpoint what is the setpoint of {device} thermostat
GetThermostatSetpoint give me the setpoint of {device} thermostat
GetThermostatSetpoint tell me the setpoint of {device} thermostat
GetThermostatSetpoint {device} setpoint
GetThermostatSetpoint current setpoint
SetThermostatMode set {device} mode to {mode}
SetThermostatMode set {device} thermostat mode to {mode}
SetThermostatMode change {device} mode to {mode}
SetThermostatMode change {device} thermostat mode to {mode}
SetThermostatMode switch {device} mode to {mode}
SetThermostatMode switch {device} thermostat mode to {mode}
SetThermostatMode set mode to {mode}
SetThermostatMode set thermostat mode to {mode}
SetThermostatMode change mode to {mode}
SetThermostatMode change thermostat mode to {mode}
SetThermostatMode switch mode to {mode}
SetThermostatMode switch thermostat mode to {mode}
IncreaseThermostatSetpoint increase {device} {mode} setpoint
IncreaseThermostatSetpoint increase {device} thermostat {mode} setpoint
IncreaseThermostatSetpoint increase {device} {mode} temperature
IncreaseThermostatSetpoint increase {device} thermostat {mode} temperature
IncreaseThermostatSetpoint increase {device} setpoint
IncreaseThermostatSetpoint increase {device} thermostat setpoint
IncreaseThermostatSetpoint increase {device} temperature
IncreaseThermostatSetpoint increase {device} thermostat temperature
IncreaseThermostatSetpoint increase setpoint
IncreaseThermostatSetpoint increase thermostat setpoint
IncreaseThermostatSetpoint increase temperature
IncreaseThermostatSetpoint increase thermostat temperature
DecreaseThermostatSetpoint decrease {device} {mode} setpoint
DecreaseThermostatSetpoint decrease {device} thermostat {mode} setpoint
DecreaseThermostatSetpoint decrease {device} {mode} temperature
DecreaseThermostatSetpoint decrease {device} thermostat {mode} temperature
DecreaseThermostatSetpoint decrease {device} setpoint
DecreaseThermostatSetpoint decrease {device} thermostat setpoint
DecreaseThermostatSetpoint decrease {device} temperature
DecreaseThermostatSetpoint decrease {device} thermostat temperature
DecreaseThermostatSetpoint decrease setpoint
DecreaseThermostatSetpoint decrease thermostat setpoint
DecreaseThermostatSetpoint decrease temperature
DecreaseThermostatSetpoint decrease thermostat temperature
RunProgram run {program}
RunProgram run program {program}
RunProgram execute {program}
RunProgram execute program {program}
RunProgram run
RunProgram execute
StopProgram stop {program}
StopProgram stop program {program}
GetProgramStatus get the status of program {program}
GetProgramStatus get status of program {program}
GetProgramStatus get status for program {program}
GetProgramStatus get the status for program {program}
GetProgramStatus the status of program {program}
GetProgramStatus status of program {program}
GetProgramStatus status for program {program}
GetProgramStatus program status of {program}
GetProgramStatus the program status of {program}
GetProgramStatus the status for program {program}
GetProgramStatus what's the status of program {program}
GetProgramStatus what is the status of program {program}
GetProgramStatus what's the status for program {program}
GetProgramStatus what is the status for program {program}
GetProgramStatus give me the status of program {program}
GetProgramStatus give me the status for program {program}
GetProgramStatus tell me the status of program {program}
GetProgramStatus tell me the status for program {program}
ReplyDegrees {degrees}
ReplyDegrees {degrees} degrees
ReplyTopic {topic}
ReplyDevice {device}
ReplyProgram {program}
ReplyMode {mode}
ReplyISY {isy}
HelpMain get help on {topic}
HelpMain can i get help on {topic}
HelpMain help on {topic}
HelpMain need help on {topic}
HelpMain I need help on {topic}
HelpMain {topic}
HelpMain what can I ask you
HelpMain get help
HelpMain what commands can I ask
HelpMain what commands can I say
HelpMain what commands can I tell
HelpMain what can I do
HelpMain what can I use this for
HelpMain what can you do
HelpMain what do you do
HelpMain how do I use you
HelpMain how can I use you
I say "to" just didn't type it.  I give up.  I will wait for the next version
And this is the list of sample devices. This does not mean that a device outside this list won't work.
front door
side door
rear door
garage door
small garage door
porch
front porch
front entry
front yard
garage front
exterior
tree
garage
garage neon
kitchen
kitchen window
kitchen sink
kitchen island
kitchen desk
kitchen area
kitchen table
pantry
living
living room
parlour
dining
dining room
computer room
games room
guest room
office
library
music room
attic
box room
locker
master room
cinema
front cinema
rear cinema
hall
hallway
upper hallway
lower hallway
guest's hallway
landing
basement
basement's bedroom
cellar
utility
utility room
main toilet
first floor toilet
second floor toilet
upper toilet
lower toilet
basement toilet
bathroom
main bathroom
master's bathroom
first floor bathroom
second floor bathroom
upper bathroom
lower bathroom
basement bathroom
washroom
first floor washroom
second floor washroom
upper washroom
lower washroom
basement washroom
deck
swimming
swimming pool
pool
lanai
upstairs
desk
desk room
island
island sink
downstairs
great room
family room
entrance
yard
barn
patio
driveway
walkway
stairs
steps
holiday
christmas
breezeway
entry
foyer
laundry
laundry room
t. v.
theater
receiver
stereo
wall sconce
wall light
wall lights
sconce
fireplace
den
den right lamp
den left lamp
study
study room
entertainment
entertainment room
breakfast table
breakfast area
sprinkler
front sprinkler
side sprinkler
rear sprinkler
left sprinkler
right sprinkler
from door
fan
heater
chime
door chime
chime mode
air conditioner
first floor
second floor
third floor
fourth floor
fifth floor
sixth floor
seventh floor
eight floor
ninth floor
tenth floor
zone one
zone two
zone three
zone four
zone five
zone six
zone seven
zone eight
very long device name
bedroom
guest's room
guest's bedroom
master's bedroom
boy's bedroom
girls's bedroom
kid's bedroom
children's bedroom
sally's bedroom
andrea's bedroom
jess's room,
mary's room,
erin's room,
greg's bedroom,
katie's bedroom
mary's bedroom
patricia's bedroom
linda's bedroom
barbara's bedroom
elizabeth's bedroom
jennifer's bedroom
maria's bedroom
james's bedroom
john's bedroom
robert's bedroom
michael's bedroom
william's bedroom
david's bedroom
richard's bedroom
charles's bedroom
joseph's bedroom
Madcodger,
Best of luck,
Chuck
I don't think you can connect Mobilinc using the ISY Portal but need to connect using DDNS.  Mobilinc setup offers only one password and username and you don't need to specify ports.  I think there is some type of integration planned but not sure of it.  Anyway.. I believe there is a rival to Mobilinc in the works.
Jon...
When you say it does not work, what does it say exactly? Is this just a beep then it closes? Or does it say something that it could not find ... in ...'s profile?
If so, this means the skill is not invoked and unfortunately the next version won't help.
If you clearly pronounce the TO. It may be the pronunciation of the skill name, which should be "izzy".
Benoit
Benoit
If it was the way I say Izzy why would it open the skill when I say open Izzy?
I don't have problems when I tell Alexa to do other things that have nothing to do with Izzy. Play music, volume up/down, what's the weather/time all work.
I do think that the limitations are on Amazons side and in time they will improve.
      380.1k
