jwarner964 Posted October 17, 2015 Posted October 17, 2015 Hi All I have a insteon thermostat and it doesn't update the temp at every degree , shouldn't it update to the ISY when ever the temp changes in the house ? Is my thermostat not working right ? Thanks Jeff
larryllix Posted October 18, 2015 Posted October 18, 2015 Most find the 2441 series update about every 1.5 degrees. This true on my 2441ZTH units I have. I believe the setpoints to be more accurate and only the reporting suffers from this.
smokegrub Posted October 18, 2015 Posted October 18, 2015 Most find the 2441 series update about every 1.5 degrees. This true on my 2441ZTH units I have. I believe the setpoints to be more accurate and only the reporting suffers from this. That has been my experience with my wireless thermostat.
larryllix Posted October 18, 2015 Posted October 18, 2015 That has been my experience with my wireless thermostat. The resolution accuracy of setting on thermostats at 0.5 degree C is bad enough.
