Is it ok to share ISY port with other devices?
My ISY is using the default ports 80 for HTTP and 443 for SSL. That said, I also have another device WIFI-IR to control all of my AV equipment which also uses port 80. Is this practice ok, or should I change the ISY HTTP port to one which isn't in use?
Thank you,
Chuck
On devices with different IP addresses, this is perfectly fine. If you need to NAT access from the Internet then you can configure your NAT to use different external ports to map to whatever IP/port combos are necessary for your devices.
