Multiple remotelinc2's with same scenes
When I try to update a remotelinc2 that has a scene in common with another remotelinc2, it says they remotelinc cannot be found (becuase I have not put it in learning mode I assume).  However when i try to put both remotelinc2s in learning mode they just beep and go back to normal standby mode.
Place both remotes in linking mode first, the update the scene. Note that the RemoteLinc2 sometimes needs to be distant from the PLM in order to update. Mine needed to be about 40' away. There should be a dual-band device other than the PLM reachable from the RemoteLincs
You can only have one battery operated device in linking mode at a time.
Otherwise you will link the two together or cancel the update process.
Ideals are peaceful - History is violent
