October 29, 201510 yr Smartlabs has officially released a Insteon enabled heat pump thermostat indicated as model 2732-242. The pre order page is available here and provides more details and specifications of this new Insteon addition: http://www.smarthome.com/insteon-2732-242-thermostat-for-heat-pump.html Full Users Manual can be found here: http://cache-m2.smarthome.com/manuals/2732-242-en-102615.pdf Selling price is $149.99 USD Edited October 29, 201510 yr by Teken
October 29, 201510 yr That is a good thing. There where many Insteon homes with heat pumps and no way to use the existing Insteon models. This morning I got an email from Smarthome announcing the new model. Has the same FCC ID number. My thoughts are the firmware has been changed to use the outputs that are used for a Heat Pump. Edited October 30, 201510 yr by Brian H
March 26, 201610 yr I have just checked the heat pump thermostat and it is having the good specifications that can be easily controlled by your smartphone and tablets.
