How to set program as controller for a scene
Hey everyone, this is going to sound very trivial I'm sure but I'm struggling with the logic around scenes. The programming is coming along because it makes logical sense to me, scenes however are a different story. I have setup a very simple scene "All lights off' with 3 switches as responders. I would like that scene to be called by a program however; when I set the switches at 0% without a controller in the scene itself, all lights go out. I am missing something so simple, just can't figure it out.
Hi
0% = Off, 100% is on.  So if its being set at 0%, its working as expected.
If dimmers are involved, percentages in between will be some level of dim.
If this isn't what you meant, can you post an image of the admin console screen with the participants in it?
Paul
Edit: Some switches bought in bundles are preset with scenes in them. If the above isn't it, I would factory reset them, and then 'restore device' to each
Edited by paulbates
I knew it was too simple an "issue", almost embarrassed  to let you all in on the resolution. I was creating the scene from my iPhone; to small a screen to realize I was setting the current state not the on state. yikes.
