Brultech - How are GEM nodes supposed to look in the ISY console?
I think i am nearly there.
I eventually got the GEM and Nodelink - much faffing with GEM as i already had IP/COM1 and COM2 in use (would be great to have an option to get data from the dahsbox by supporting packet format 4 as the dashbox will relay COM2)  but I digress.
I got the nodes created in the ISY and i have some questions:
1) why are the nodes in a seemingly random order? (oh on next logon they ordered them selves correctly, how odd!)
2) do they have to say n001_xxx or can we drop the n001 suffix?  I worked out while writing this post i can group and manually edit them so i guess that's good workaround
3) sometimes when i add the channels it only adds some (16 just now), clicking install ISY nodes again seems to have added the remaining channels.  Oh i just noticed the first click add the even channels and the second click adds the odd channels!
4) the nodes don't seem to display anything in the main tree view - is that normal?  I assumed it would show power and total usage? also the nodes are all marked as red - is that a bad sign?
5) any pros / cons of packet format 2 vs 14?
alex
Edited by Scyto
I don't think supporting format 4 would make a difference.  I believe you have to discretely send to the DB's IP address with format 4 anyway.  Format 4 would only be useful if the GEM could broadcast (could be wrong here since I don't own a GEM).
1.  Just hit the A-Z in the ISY admin console
2.  n001 is mandatory - this is part of ISY's Node Server requirement.  Just rename them as desired.
3.  The REST calls must be failing going to the ISY.  Hitting again is basically a retry - anything in the log?
4.  Tree view should show Amps.
5.  Doesn't matter
On the nodes not showing anything.
I re-uploaded the profile / nodesetup file to the ISY and as part of portal troubleshooting i did another hard reboot.
Now when i click a node the UI has UI (boxes that say things like voltage / current / power day of week etc depending on the node) and the nodes now have icons they didn't have before.
however the boxes have no values they are blank.
I deleted the test node (other ISY data) and clicked the re-install, that didn't seem to work, i see data like this with verbose logging:
2015-11-23 10:19:51 - ok(P) [gem]
2015-11-23 10:20:06 - ok(P) [gem]
2015-11-23 10:20:16 - Web Request: /general.css
2015-11-23 10:20:17 - Web Request: /config.htm
2015-11-23 10:20:17 - Web Request: /general.css
2015-11-23 10:20:18 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.4
/72)
2015-11-23 10:20:21 - ISY: Variable gem-ST replaced in queue (Val: 122.0
, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1601, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 104, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 7, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 270, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 63, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 4, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan24-GV1 replaced in queue (Val: 53, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 643, QS: 108)
2015-11-23 10:20:21 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 211, QS: 108)
2015-11-23 10:20:21 - ok(P) [gem]
2015-11-23 10:20:22 - Web Request: /devices.htm
2015-11-23 10:20:22 - Web Request: /general.css
2015-11-23 10:20:25 - Web Request: /gem.htm
2015-11-23 10:20:25 - Web Request: /general.css
2015-11-23 10:20:32 - ISY: Variable test-GV3 replaced in queue (Val: 470061, QS: 108)
2015-11-23 10:20:34 - Web Request: /test.htm
2015-11-23 10:20:35 - Web Request: /general.css
2015-11-23 10:20:36 - ISY: Variable gem-ST replaced in queue (Val: 121.6
, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1610, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 79.29, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 9, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 268, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 64, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 3, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 642, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 12.29, QS: 108)
2015-11-23 10:20:36 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 210, QS: 108)
2015-11-23 10:20:36 - ok(P) [gem]
2015-11-23 10:20:45 - ISY:  (ns/1/nodes/n001_test/add/ISYData?primary=n001_test&name=n001_test&nls=139D)
2015-11-23 10:20:45 - Web Request: /general.css
2015-11-23 10:20:48 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.6
/72)
2015-11-23 10:20:51 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1600, QS: 108)
2015-11-23 10:20:51 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 79.3, QS: 108)
2015-11-23 10:20:51 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 264, QS: 108)
2015-11-23 10:20:51 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 108)
2015-11-23 10:20:51 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 1, QS: 108)
2015-11-23 10:20:51 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 644, QS: 108)
2015-11-23 10:20:51 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 206, QS: 108)
2015-11-23 10:20:51 - ok(P) [gem]
2015-11-23 10:20:53 - Web Request: /isylink/nodes/n001_test/cmd/QUERY
2015-11-23 10:20:57 - ISY: Variable test-GV1 replaced in queue (Val: 10, QS: 108)
2015-11-23 10:20:57 - ISY: Variable test-GV2 replaced in queue (Val: 20, QS: 108)
2015-11-23 10:20:57 - ISY: Variable test-GV3 replaced in queue (Val: 470061, QS: 108)
2015-11-23 10:20:57 - ISY: Variable test-GV4 replaced in queue (Val: 1, QS: 108)
2015-11-23 10:20:57 - ISY: Variable test-GV5 replaced in queue (Val: 48, QS: 108)
2015-11-23 10:20:57 - ISY: Variable test-GV6 replaced in queue (Val: 1, QS: 108)
2015-11-23 10:20:58 - ISY: Variable test-GV7 replaced in queue (Val: 11, QS: 108)
2015-11-23 10:20:58 - ISY: Variable test-GV8 replaced in queue (Val: 23, QS: 108)
2015-11-23 10:20:58 - ISY: Variable test-GV9 replaced in queue (Val: 2015, QS: 108)
2015-11-23 10:20:58 - ISY: Variable test-GV10 replaced in queue (Val: 327, QS: 108)
2015-11-23 10:20:58 - ISY: Variable test-GV11 replaced in queue (Val: 3, QS: 108)
2015-11-23 10:21:03 - ISY: Variable test-GV2 replaced in queue (Val: 21, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem-ST replaced in queue (Val: 121.5
, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1615, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 105, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 2, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 642, QS: 108)
2015-11-23 10:21:06 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 213, QS: 108)
2015-11-23 10:21:06 - ok(P) [gem]
2015-11-23 10:21:19 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.5
/72)
2015-11-23 10:21:21 - ISY: Variable gem-ST replaced in queue (Val: 121.7
, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1647, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 79.31, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 110, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 263, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan08-GV2 replaced in queue (Val: 3.43, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 662, QS: 108)
2015-11-23 10:21:21 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 212, QS: 108)
2015-11-23 10:21:21 - ok(P) [gem]
2015-11-23 10:21:33 - ISY: Variable test-GV3 replaced in queue (Val: 470062, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem-ST replaced in queue (Val: 121.6
, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1615, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 79.32, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 104, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 262, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan22-GV1 replaced in queue (Val: 2, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 639, QS: 108)
2015-11-23 10:21:36 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 12.3, QS: 108)
2015-11-23 10:21:36 - ok(P) [gem]
2015-11-23 10:21:50 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.6
/72)
2015-11-23 10:21:51 - ISY: Variable gem-ST replaced in queue (Val: 121.5
, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1613, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 105, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan05-GV1 replaced in queue (Val: 39, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 263, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 4, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan22-GV1 replaced in queue (Val: 1, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 641, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 211, QS: 108)
2015-11-23 10:21:51 - ISY: Variable gem_chan30-GV2 replaced in queue (Val: 5.43, QS: 108)
2015-11-23 10:21:51 - ok(P) [gem]
2015-11-23 10:22:03 - ISY: Variable test-GV2 replaced in queue (Val: 22, QS: 108)
2015-11-23 10:22:06 - ISY: Variable gem-ST replaced in queue (Val: 121.6
, QS: 108)
2015-11-23 10:22:06 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1631, QS: 108)
2015-11-23 10:22:06 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 79.33, QS: 108)
2015-11-23 10:22:06 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 266, QS: 108)
2015-11-23 10:22:06 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 669, QS: 108)
2015-11-23 10:22:06 - ok(P) [gem]
2015-11-23 10:22:20 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.6
/72)
2015-11-23 10:22:21 - ISY: Variable gem-ST replaced in queue (Val: 121.9
, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1575, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 79.34, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 104, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan07-GV1 replaced in queue (Val: 106, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 238, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 63, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 648, QS: 108)
2015-11-23 10:22:21 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 12.31, QS: 108)
2015-11-23 10:22:21 - ok(P) [gem]
2015-11-23 10:22:25 - Web Request: /index.htm
2015-11-23 10:22:26 - Web Request: /general.css
2015-11-23 10:22:26 - Web Request: /index.htm
Having the empty boxes is correct and what you should see until NodeLink populates the boxes with values.
The 404 error is the issue, your node it not installed or setup correctly.
NodeLink is trying to write a value of 121.6 to the main node of device gem.  The 404 means that node doesn't exist in the ISY.
not sure what to say, there is a node there, i will delete them and re add and see if that changes anything
On re-add, i saw this:
2015-11-23 12:32:36 - ok(P) [gem]
2015-11-23 12:32:40 - ISY:  (ns/1/nodes/n001_gem/add/GreenEye?primary=n001_gem&name=n001_gem&nls=143)
2015-11-23 12:32:40 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2015-11-23 12:32:40 - ISY:  (ns/1/nodes/n001_gem_chan02/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan02&nls=143C)
2015-11-23 12:32:40 - ISY:  (ns/1/nodes/n001_gem_chan04/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan04&nls=143C)
2015-11-23 12:32:41 - ISY:  (ns/1/nodes/n001_gem_chan06/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan06&nls=143C)
2015-11-23 12:32:41 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2015-11-23 12:32:41 - ISY:  (ns/1/nodes/n001_gem_chan08/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan08&nls=143C)
2015-11-23 12:32:41 - ISY:  (ns/1/nodes/n001_gem_chan10/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan10&nls=143C)
2015-11-23 12:32:42 - ISY:  (ns/1/nodes/n001_gem_chan12/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan12&nls=143C)
2015-11-23 12:32:42 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2015-11-23 12:32:42 - ISY:  (ns/1/nodes/n001_gem_chan14/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan14&nls=143C)
2015-11-23 12:32:42 - ISY:  (ns/1/nodes/n001_gem_chan16/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan16&nls=143C)
2015-11-23 12:32:42 - ISY:  (ns/1/nodes/n001_gem_chan18/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan18&nls=143C)
2015-11-23 12:32:43 - ISY:  (ns/1/nodes/n001_gem_chan20/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan20&nls=143C)
2015-11-23 12:32:43 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2015-11-23 12:32:43 - ISY:  (ns/1/nodes/n001_gem_chan22/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan22&nls=143C)
2015-11-23 12:32:43 - ISY:  (ns/1/nodes/n001_gem_chan24/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan24&nls=143C)
2015-11-23 12:32:44 - ISY:  (ns/1/nodes/n001_gem_chan26/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan26&nls=143C)
2015-11-23 12:32:44 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2015-11-23 12:32:44 - ISY:  (ns/1/nodes/n001_gem_chan28/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan28&nls=143C)
2015-11-23 12:32:44 - ISY:  (ns/1/nodes/n001_gem_chan30/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan30&nls=143C)
2015-11-23 12:32:44 - ISY:  (ns/1/nodes/n001_gem_chan32/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan32&nls=143C)
2015-11-23 12:32:44 - Web Request: /general.css
2015-11-23 12:32:51 - ISY: Variable gem-ST replaced in queue (Val: 121.3
, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1258, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 105, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 18, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 3, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 0, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 639, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 13.68, QS: 108)
2015-11-23 12:32:51 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 202, QS: 108)
2015-11-23 12:32:51 - ok(P) [gem]
2015-11-23 12:32:56 - Web Request: /index.htm
2015-11-23 12:32:57 - Web Request: /index.htm
2015-11-23 12:32:58 - Web Request: /index.htm
should i be using the node servers > isylink > add nodes functionality?
No, you should be adding them via the NodeLink device config page.  That ensures the details are created properly.
The ReadDone2 errors are odd, I believe they are a mono bug (apparently fixed in >=4.2.0).  I don't have retry logic for these errors while adding nodes, try disabling Keep-Alive under the System Config tab of NodeLink.
Edited by io_guy
do you want me to update mono on the PI?  i am not sure what version it is.
changing the keep alive made it so all 32 channels got added in one operation.  Still red and no data in them.
015-11-23 14:33:52 - Web Request: /gem.htm
2015-11-23 14:33:52 - Web Request: /general.css
2015-11-23 14:34:01 - ISY:  (ns/1/nodes/n001_gem/add/GreenEye?primary=n001_gem&name=n001_gem&nls=143)
2015-11-23 14:34:01 - ISY:  (ns/1/nodes/n001_gem_chan01/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan01&nls=143C)
2015-11-23 14:34:01 - ISY:  (ns/1/nodes/n001_gem_chan02/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan02&nls=143C)
2015-11-23 14:34:02 - ISY: Variable test-GV2 replaced in queue (Val: 34, QS: 111)
2015-11-23 14:34:02 - ISY:  (ns/1/nodes/n001_gem_chan03/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan03&nls=143C)
2015-11-23 14:34:02 - ISY:  (ns/1/nodes/n001_gem_chan04/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan04&nls=143C)
2015-11-23 14:34:03 - ISY:  (ns/1/nodes/n001_gem_chan05/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan05&nls=143C)
2015-11-23 14:34:03 - ISY:  (ns/1/nodes/n001_gem_chan06/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan06&nls=143C)
2015-11-23 14:34:03 - ISY:  (ns/1/nodes/n001_gem_chan07/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan07&nls=143C)
2015-11-23 14:34:04 - ISY:  (ns/1/nodes/n001_gem_chan08/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan08&nls=143C)
2015-11-23 14:34:04 - ISY:  (ns/1/nodes/n001_gem_chan09/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan09&nls=143C)
2015-11-23 14:34:04 - ISY:  (ns/1/nodes/n001_gem_chan10/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan10&nls=143C)
2015-11-23 14:34:05 - ISY:  (ns/1/nodes/n001_gem_chan11/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan11&nls=143C)
2015-11-23 14:34:05 - ISY:  (ns/1/nodes/n001_gem_chan12/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan12&nls=143C)
2015-11-23 14:34:06 - ISY: Variable gem-ST replaced in queue (Val: 121.4
, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1386, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 88.99, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan07-GV1 replaced in queue (Val: 111, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 18, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan22-GV1 replaced in queue (Val: 2, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 712, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 14.96, QS: 111)
2015-11-23 14:34:06 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 209, QS: 111)
2015-11-23 14:34:06 - ISY:  (ns/1/nodes/n001_gem_chan13/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan13&nls=143C)
2015-11-23 14:34:06 - ok(P) [gem]
2015-11-23 14:34:06 - ISY:  (ns/1/nodes/n001_gem_chan14/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan14&nls=143C)
2015-11-23 14:34:06 - ISY:  (ns/1/nodes/n001_gem_chan15/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan15&nls=143C)
2015-11-23 14:34:07 - ISY:  (ns/1/nodes/n001_gem_chan16/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan16&nls=143C)
2015-11-23 14:34:07 - ISY:  (ns/1/nodes/n001_gem_chan17/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan17&nls=143C)
2015-11-23 14:34:08 - ISY:  (ns/1/nodes/n001_gem_chan18/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan18&nls=143C)
2015-11-23 14:34:08 - ISY:  (ns/1/nodes/n001_gem_chan19/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan19&nls=143C)
2015-11-23 14:34:09 - ISY:  (ns/1/nodes/n001_gem_chan20/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan20&nls=143C)
2015-11-23 14:34:09 - ISY:  (ns/1/nodes/n001_gem_chan21/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan21&nls=143C)
2015-11-23 14:34:09 - ISY:  (ns/1/nodes/n001_gem_chan22/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan22&nls=143C)
2015-11-23 14:34:10 - ISY:  (ns/1/nodes/n001_gem_chan23/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan23&nls=143C)
2015-11-23 14:34:10 - ISY:  (ns/1/nodes/n001_gem_chan24/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan24&nls=143C)
2015-11-23 14:34:11 - ISY:  (ns/1/nodes/n001_gem_chan25/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan25&nls=143C)
2015-11-23 14:34:12 - ISY:  (ns/1/nodes/n001_gem_chan26/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan26&nls=143C)
2015-11-23 14:34:12 - ISY:  (ns/1/nodes/n001_gem_chan27/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan27&nls=143C)
2015-11-23 14:34:13 - ISY:  (ns/1/nodes/n001_gem_chan28/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan28&nls=143C)
2015-11-23 14:34:13 - ISY:  (ns/1/nodes/n001_gem_chan29/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan29&nls=143C)
2015-11-23 14:34:14 - ISY:  (ns/1/nodes/n001_gem_chan30/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan30&nls=143C)
2015-11-23 14:34:14 - ISY:  (ns/1/nodes/n001_gem_chan31/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan31&nls=143C)
2015-11-23 14:34:14 - ISY:  (ns/1/nodes/n001_gem_chan32/add/GreenEyeChannel?primary=n001_gem&name=n001_gem_chan32&nls=143C)
2015-11-23 14:34:14 - Web Request: /general.css
2015-11-23 14:34:17 - Web Request: /index.htm
Don't bother updating mono, raspbian still uses an outdated version.
I don't see any errors in your last log?
though. now the general data test node is working just fine  (still appears red but has data populated).
still getting this for the GEM node 2015-11-23 14:37:25 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/120.9
/72)
015-11-23 14:37:22 - Web Request: /general.css
2015-11-23 14:37:24 - ISY:  (ns/1/nodes/n001_test/report/status/GV1/14/25)
2015-11-23 14:37:24 - ISY:  (ns/1/nodes/n001_test/report/status/GV2/37/25)
2015-11-23 14:37:24 - ISY:  (ns/1/nodes/n001_test/report/status/GV3/470317/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV4/1/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV5/48/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV6/1/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV7/11/47)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV8/23/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV9/2015/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV10/327/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test/report/status/GV11/3/25)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test_sun/report/status/GV1/219/14)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test_sun/report/status/GV2/13/14)
2015-11-23 14:37:25 - ISY:  (ns/1/nodes/n001_test_sun/report/status/GV3/77/14)
/72)
2015-11-23 14:37:32 - ISY: Variable test-GV3 added to queue (Val: 470318, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1310, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 104, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan07-GV1 replaced in queue (Val: 104, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 18, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 638, QS: 98)
2015-11-23 14:37:36 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 210, QS: 98)
2015-11-23 14:37:36 - ok(P) [gem]
2015-11-23 14:37:50 - Web Request: /index.htm
I spoke too soon about the test node, while it initially populated with data, it hasn't changed since that population (time hasn't changed).
--edit- rebooting nodelink repopulated the general node, still no effect on the GEM node, but still no realtime updating:
--edit added spoiler tag as it was obnoxious to have this all in the post expanded.
2015-11-23 15:25:03 - ISY NodeLink Server v0.2.1 started
2015-11-23 15:25:05 - ISY resolved to 192.168.1.97
2015-11-23 15:25:06 - Web config server started (http://192.168.1.118:8090)
2015-11-23 15:25:06 - ISY: Variable list request sent
2015-11-23 15:25:06 - Web Request: /index.htm
2015-11-23 15:25:06 - Web Request: /general.css
2015-11-23 15:25:07 - <cut variable errors from here>
2015-11-23 15:25:07 - Auto-Update: Checking for program update...
2015-11-23 15:25:08 - Auto-Update: No web update available
2015-11-23 15:25:08 - <cut climate info here - odd doesn't appear in UI but is in underlying html>
2015-11-23 15:25:09 - ISY: Variable test-GV1 added to queue (Val: 15, QS: 1)
2015-11-23 15:25:09 - ISY: Variable test-GV2 added to queue (Val: 25, QS: 2)
2015-11-23 15:25:09 - ISY: Variable test-GV3 added to queue (Val: 470365, QS: 3)
2015-11-23 15:25:09 - ISY: Variable test-GV4 added to queue (Val: 1, QS: 4)
2015-11-23 15:25:09 - ISY: Variable test-GV5 added to queue (Val: 48, QS: 5)
2015-11-23 15:25:09 - ISY: Variable test-GV6 added to queue (Val: 1, QS: 6)
2015-11-23 15:25:09 - ISY: Variable test-GV7 added to queue (Val: 11, QS: 7)
2015-11-23 15:25:09 - ISY: Variable test-GV8 added to queue (Val: 23, QS: 8)
2015-11-23 15:25:09 - ISY: Variable test-GV9 added to queue (Val: 2015, QS: 9)
2015-11-23 15:25:09 - ISY: Variable test-GV10 added to queue (Val: 327, QS: 10)
2015-11-23 15:25:09 - ISY: Variable test-GV11 added to queue (Val: 3, QS: 11)
2015-11-23 15:25:10 - ISY: Variable test_sun-GV1 added to queue (Val: 228, QS: 12)
2015-11-23 15:25:10 - ISY: Variable test_sun-GV2 added to queue (Val: 7, QS: 13)
2015-11-23 15:25:10 - ISY: Variable test_sun-GV3 added to queue (Val: 83, QS: 14)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV1/15/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV2/25/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV3/470365/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV4/1/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV5/48/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV6/1/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV7/11/47)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV8/23/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV9/2015/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV10/327/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test/report/status/GV11/3/25)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test_sun/report/status/GV1/228/14)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test_sun/report/status/GV2/7/14)
2015-11-23 15:25:10 - ISY:  (ns/1/nodes/n001_test_sun/report/status/GV3/83/14)
2015-11-23 15:25:18 - Web Request: /index.htm
2015-11-23 15:25:18 - Web Request: /general.css
2015-11-23 15:25:21 - ISY: Variable gem-ST added to queue (Val: 121.2
, QS: 1)
2015-11-23 15:25:21 - ISY: Variable gem_chan01-ST added to queue (Val: 0, QS: 2)
2015-11-23 15:25:21 - ISY: Variable gem_chan01-GV1 added to queue (Val: 1282, QS: 3)
2015-11-23 15:25:21 - ISY: Variable gem_chan01-GV2 added to queue (Val: 91.12, QS: 4)
2015-11-23 15:25:21 - ISY: Variable gem_chan02-ST added to queue (Val: 0, QS: 5)
2015-11-23 15:25:21 - ISY: Variable gem_chan02-GV1 added to queue (Val: 2, QS: 6)
2015-11-23 15:25:21 - ISY: Variable gem_chan02-GV2 added to queue (Val: 0.11, QS: 7)
2015-11-23 15:25:21 - ISY: Variable gem_chan03-ST added to queue (Val: 0, QS: 8)
2015-11-23 15:25:21 - ISY: Variable gem_chan03-GV1 added to queue (Val: 0, QS: 9)
2015-11-23 15:25:21 - ISY: Variable gem_chan03-GV2 added to queue (Val: 44, QS: 10)
2015-11-23 15:25:21 - ISY: Variable gem_chan04-ST added to queue (Val: 0, QS: 11)
2015-11-23 15:25:21 - ISY: Variable gem_chan04-GV1 added to queue (Val: 105, QS: 12)
2015-11-23 15:25:21 - ISY: Variable gem_chan04-GV2 added to queue (Val: 4.22, QS: 13)
2015-11-23 15:25:21 - ISY: Variable gem_chan05-ST added to queue (Val: 0, QS: 14)
2015-11-23 15:25:21 - ISY: Variable gem_chan05-GV1 added to queue (Val: 0, QS: 15)
2015-11-23 15:25:21 - ISY: Variable gem_chan05-GV2 added to queue (Val: 0.65, QS: 16)
2015-11-23 15:25:21 - ISY: Variable gem_chan06-ST added to queue (Val: 0, QS: 17)
2015-11-23 15:25:21 - ISY: Variable gem_chan06-GV1 added to queue (Val: 13, QS: 18)
2015-11-23 15:25:21 - ISY: Variable gem_chan06-GV2 added to queue (Val: 0.7, QS: 19)
2015-11-23 15:25:21 - ISY: Variable gem_chan07-ST added to queue (Val: 0, QS: 20)
2015-11-23 15:25:21 - ISY: Variable gem_chan07-GV1 added to queue (Val: 70, QS: 21)
2015-11-23 15:25:21 - ISY: Variable gem_chan07-GV2 added to queue (Val: 1.56, QS: 22)
2015-11-23 15:25:21 - ISY: Variable gem_chan08-ST added to queue (Val: 0, QS: 23)
2015-11-23 15:25:21 - ISY: Variable gem_chan08-GV1 added to queue (Val: 18, QS: 24)
2015-11-23 15:25:21 - ISY: Variable gem_chan08-GV2 added to queue (Val: 3.74, QS: 25)
2015-11-23 15:25:21 - ISY: Variable gem_chan09-ST added to queue (Val: 0, QS: 26)
2015-11-23 15:25:21 - ISY: Variable gem_chan09-GV1 added to queue (Val: 2, QS: 27)
2015-11-23 15:25:21 - ISY: Variable gem_chan09-GV2 added to queue (Val: 0.37, QS: 28)
2015-11-23 15:25:21 - ISY: Variable gem_chan10-ST added to queue (Val: 0, QS: 29)
2015-11-23 15:25:21 - ISY: Variable gem_chan10-GV1 added to queue (Val: 9, QS: 30)
2015-11-23 15:25:21 - ISY: Variable gem_chan10-GV2 added to queue (Val: 0.65, QS: 31)
2015-11-23 15:25:21 - ISY: Variable gem_chan11-ST added to queue (Val: 0, QS: 32)
2015-11-23 15:25:21 - ISY: Variable gem_chan11-GV1 added to queue (Val: 5, QS: 33)
2015-11-23 15:25:21 - ISY: Variable gem_chan11-GV2 added to queue (Val: 1.26, QS: 34)
2015-11-23 15:25:21 - ISY: Variable gem_chan12-ST added to queue (Val: 0, QS: 35)
2015-11-23 15:25:21 - ISY: Variable gem_chan12-GV1 added to queue (Val: 2, QS: 36)
2015-11-23 15:25:21 - ISY: Variable gem_chan12-GV2 added to queue (Val: 0.09, QS: 37)
2015-11-23 15:25:21 - ISY: Variable gem_chan13-ST added to queue (Val: 0, QS: 38)
2015-11-23 15:25:21 - ISY: Variable gem_chan13-GV1 added to queue (Val: 0, QS: 39)
2015-11-23 15:25:21 - ISY: Variable gem_chan13-GV2 added to queue (Val: 0.01, QS: 40)
2015-11-23 15:25:21 - ISY: Variable gem_chan14-ST added to queue (Val: 0, QS: 41)
2015-11-23 15:25:21 - ISY: Variable gem_chan14-GV1 added to queue (Val: 0, QS: 42)
2015-11-23 15:25:21 - ISY: Variable gem_chan14-GV2 added to queue (Val: 0.01, QS: 43)
2015-11-23 15:25:21 - ISY: Variable gem_chan15-ST added to queue (Val: 0, QS: 44)
2015-11-23 15:25:21 - ISY: Variable gem_chan15-GV1 added to queue (Val: 4, QS: 45)
2015-11-23 15:25:21 - ISY: Variable gem_chan15-GV2 added to queue (Val: 0.18, QS: 46)
2015-11-23 15:25:21 - ISY: Variable gem_chan16-ST added to queue (Val: 0, QS: 47)
2015-11-23 15:25:21 - ISY: Variable gem_chan16-GV1 added to queue (Val: 0, QS: 48)
2015-11-23 15:25:21 - ISY: Variable gem_chan16-GV2 added to queue (Val: 0.07, QS: 49)
2015-11-23 15:25:21 - ISY: Variable gem_chan17-ST added to queue (Val: 0, QS: 50)
2015-11-23 15:25:21 - ISY: Variable gem_chan17-GV1 added to queue (Val: 1, QS: 51)
2015-11-23 15:25:21 - ISY: Variable gem_chan17-GV2 added to queue (Val: 1.28, QS: 52)
2015-11-23 15:25:21 - ISY: Variable gem_chan18-ST added to queue (Val: 0, QS: 53)
2015-11-23 15:25:21 - ISY: Variable gem_chan18-GV1 added to queue (Val: 59, QS: 54)
2015-11-23 15:25:21 - ISY: Variable gem_chan18-GV2 added to queue (Val: 4.04, QS: 55)
2015-11-23 15:25:21 - ISY: Variable gem_chan19-ST added to queue (Val: 0, QS: 56)
2015-11-23 15:25:21 - ISY: Variable gem_chan19-GV1 added to queue (Val: 27, QS: 57)
2015-11-23 15:25:21 - ISY: Variable gem_chan19-GV2 added to queue (Val: 0.47, QS: 58)
2015-11-23 15:25:21 - ISY: Variable gem_chan20-ST added to queue (Val: 0, QS: 59)
2015-11-23 15:25:21 - ISY: Variable gem_chan20-GV1 added to queue (Val: 1, QS: 60)
2015-11-23 15:25:21 - ISY: Variable gem_chan20-GV2 added to queue (Val: 0.06, QS: 61)
2015-11-23 15:25:21 - ISY: Variable gem_chan21-ST added to queue (Val: 0, QS: 62)
2015-11-23 15:25:21 - ISY: Variable gem_chan21-GV1 added to queue (Val: 1, QS: 63)
2015-11-23 15:25:21 - ISY: Variable gem_chan21-GV2 added to queue (Val: 0.08, QS: 64)
2015-11-23 15:25:21 - ISY: Variable gem_chan22-ST added to queue (Val: 0, QS: 65)
2015-11-23 15:25:21 - ISY: Variable gem_chan22-GV1 added to queue (Val: 1, QS: 66)
2015-11-23 15:25:21 - ISY: Variable gem_chan22-GV2 added to queue (Val: 0.06, QS: 67)
2015-11-23 15:25:21 - ISY: Variable gem_chan23-ST added to queue (Val: 0, QS: 68)
2015-11-23 15:25:21 - ISY: Variable gem_chan23-GV1 added to queue (Val: 1, QS: 69)
2015-11-23 15:25:21 - ISY: Variable gem_chan23-GV2 added to queue (Val: 0.05, QS: 70)
2015-11-23 15:25:21 - ISY: Variable gem_chan24-ST added to queue (Val: 0, QS: 71)
2015-11-23 15:25:21 - ISY: Variable gem_chan24-GV1 added to queue (Val: 53, QS: 72)
2015-11-23 15:25:21 - ISY: Variable gem_chan24-GV2 added to queue (Val: 2.14, QS: 73)
2015-11-23 15:25:21 - ISY: Variable gem_chan25-ST added to queue (Val: 0, QS: 74)
2015-11-23 15:25:21 - ISY: Variable gem_chan25-GV1 added to queue (Val: 0, QS: 75)
2015-11-23 15:25:21 - ISY: Variable gem_chan25-GV2 added to queue (Val: 0.25, QS: 76)
2015-11-23 15:25:21 - ISY: Variable gem_chan26-ST added to queue (Val: 0, QS: 77)
2015-11-23 15:25:21 - ISY: Variable gem_chan26-GV1 added to queue (Val: 0, QS: 78)
2015-11-23 15:25:21 - ISY: Variable gem_chan26-GV2 added to queue (Val: 0, QS: 79)
2015-11-23 15:25:21 - ISY: Variable gem_chan27-ST added to queue (Val: 0, QS: 80)
2015-11-23 15:25:21 - ISY: Variable gem_chan27-GV1 added to queue (Val: 3, QS: 81)
2015-11-23 15:25:21 - ISY: Variable gem_chan27-GV2 added to queue (Val: 0.62, QS: 82)
2015-11-23 15:25:21 - ISY: Variable gem_chan28-ST added to queue (Val: 0, QS: 83)
2015-11-23 15:25:21 - ISY: Variable gem_chan28-GV1 added to queue (Val: 26, QS: 84)
2015-11-23 15:25:21 - ISY: Variable gem_chan28-GV2 added to queue (Val: 1.06, QS: 85)
2015-11-23 15:25:21 - ISY: Variable gem_chan29-ST added to queue (Val: 0, QS: 86)
2015-11-23 15:25:21 - ISY: Variable gem_chan29-GV1 added to queue (Val: 695, QS: 87)
2015-11-23 15:25:21 - ISY: Variable gem_chan29-GV2 added to queue (Val: 15.5, QS: 88)
2015-11-23 15:25:21 - ISY: Variable gem_chan30-ST added to queue (Val: 0, QS: 89)
2015-11-23 15:25:21 - ISY: Variable gem_chan30-GV1 added to queue (Val: 156, QS: 90)
2015-11-23 15:25:21 - ISY: Variable gem_chan30-GV2 added to queue (Val: 6.44, QS: 91)
2015-11-23 15:25:21 - ISY: Variable gem_chan31-ST added to queue (Val: 0, QS: 92)
2015-11-23 15:25:21 - ISY: Variable gem_chan31-GV1 added to queue (Val: 7, QS: 93)
2015-11-23 15:25:21 - ISY: Variable gem_chan31-GV2 added to queue (Val: 0.3, QS: 94)
2015-11-23 15:25:21 - ISY: Variable gem_chan32-ST added to queue (Val: 0, QS: 95)
2015-11-23 15:25:21 - ISY: Variable gem_chan32-GV1 added to queue (Val: 0, QS: 96)
2015-11-23 15:25:21 - ISY: Variable gem_chan32-GV2 added to queue (Val: 0.01, QS: 97)
2015-11-23 15:25:21 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.2
/72)
2015-11-23 15:25:21 - ok(P) [gem]
2015-11-23 15:25:30 - ISY: Variable test-GV3 added to queue (Val: 470366, QS: 98)
2015-11-23 15:25:35 - ISY: Variable test_sun-GV1 added to queue (Val: 229, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem-ST replaced in queue (Val: 121.8
, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1260, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 91.13, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 104, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 12, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 19, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan11-GV2 replaced in queue (Val: 1.27, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 635, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 15.51, QS: 99)
2015-11-23 15:25:36 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 174, QS: 99)
2015-11-23 15:25:36 - ok(P) [gem]
2015-11-23 15:25:51 - ISY: Variable gem-ST replaced in queue (Val: 121.4
, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1309, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 105, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan04-GV2 replaced in queue (Val: 4.23, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 13, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 20, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 715, QS: 99)
2015-11-23 15:25:51 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 146, QS: 99)
2015-11-23 15:25:51 - ok(P) [gem]
2015-11-23 15:25:52 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.4
/72)
2015-11-23 15:26:00 - ISY: Variable test-GV2 added to queue (Val: 26, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem-ST replaced in queue (Val: 121.5
, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1229, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 91.14, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 11, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 18, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan10-GV1 replaced in queue (Val: 10, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 0, QS: 100)
2015-11-23 15:26:06 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 635, QS: 100)
2015-11-23 15:26:06 - ok(P) [gem]
2015-11-23 15:26:21 - ISY: Variable gem-ST replaced in queue (Val: 121.8
, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1230, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 17, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan10-GV1 replaced in queue (Val: 9, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 63, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan24-GV2 replaced in queue (Val: 2.15, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 634, QS: 100)
2015-11-23 15:26:21 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 15.52, QS: 100)
2015-11-23 15:26:21 - ok(P) [gem]
2015-11-23 15:26:22 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.8
/72)
2015-11-23 15:26:30 - ISY: Variable test-GV3 replaced in queue (Val: 470367, QS: 100)
2015-11-23 15:26:34 - Web Request: /index.htm
2015-11-23 15:26:34 - Web Request: /general.css
2015-11-23 15:26:36 - ISY: Variable gem-ST replaced in queue (Val: 121.6
, QS: 100)
2015-11-23 15:26:36 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1334, QS: 100)
2015-11-23 15:26:36 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 91.15, QS: 100)
2015-11-23 15:26:36 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 114, QS: 100)
2015-11-23 15:26:36 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 64, QS: 100)
2015-11-23 15:26:36 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 638, QS: 100)
2015-11-23 15:26:36 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 147, QS: 100)
2015-11-23 15:26:36 - ok(P) [gem]
2015-11-23 15:26:51 - ISY: Variable gem-ST replaced in queue (Val: 121.5
, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1313, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 101, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 18, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 62, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 26, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 1, QS: 100)
2015-11-23 15:26:51 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 633, QS: 100)
2015-11-23 15:26:51 - ok(P) [gem]
2015-11-23 15:26:53 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.5
/72)
2015-11-23 15:27:00 - ISY: Variable test-GV2 replaced in queue (Val: 27, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem-ST replaced in queue (Val: 121.6
, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1351, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 91.16, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 106, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 63, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 27, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 2, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 663, QS: 100)
2015-11-23 15:27:06 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 146, QS: 100)
2015-11-23 15:27:06 - Web Request: /index.htm
2015-11-23 15:27:07 - ok(P) [gem]
2015-11-23 15:27:11 - Web Request: /index.htm
Edited by Scyto
The 404 is saying the node doesn't exist in the ISY.
When you click on the main GEM node in the ISY does it show the address as n001_gem?
Yes, will send some screen shots when I get back home later.
 some screenshots attached. i looked in the ISY log and all i found that referenced the nodelink server was a few entries like this:
2015/11/23 15:10:46 System -170001 [HTTP:0-25-5] 192.168.1.118:33126->80
2015/11/23 15:10:46 System -170001 [HTTP:0-25]: GET-->/rest/ns/1/nodes/n001_gem/re
2015/11/23 15:10:59 System -170001 [HTTP:0-25-5] 192.168.1.118:33128->80
2015/11/23 15:10:59 System -170001 [HTTP:0-25]: GET-->/rest/vars/set/2/10/1
Edited by Scyto
I believe its related to the ISYData node and the Latitude and Longitude values. If you specify these values, the isydata node quits updating. I also had issues with my other nodes, venstar nodes in my case.
I can suggest what worked for me. Edit your config.xml, toward the bottom, remove the entire section with the latitude and longitude in it. Save it and restart the nodeserver.
Edited by paulbates
Didn't make any difference on my system.
I looked in the XML, i did notice that when i deleted a device in the UI (brultechgem) it didn't delete from the XML file.
I manually removed the orphaned device section and the section for device test and restart the node server - but no change (i ill try removing and re-adding all the devices again.  The original XML is attached as FYI.
config.xml.broken.txt
Edited by Scyto
restart the isy as well
yay for the isy portal, no having to run downstairs to pull the plug any more!
  • I deleted all the devices
  • re-added my gem device and test devices by clikcing the install ISY node on each of the devices pages
  • rebooted nodelink - no data
  • rebooted ISY - no data
  • rebooted nodelink - now data showed up in the 'test' device node (hour,minutes etc)
  • but no data showed up in the gem device nodes
  • data in the test device node is not refreshing - attached is the running XML file
whats interesting is i am not now getting the gem node errors, as follows it now seems to be ok, but the data is not showing up.
 ok(P) [gem]
2015-11-23 19:21:16 - Web Request: /isylink/nodes/n001_gem_chan17/query?requestId=163
2015-11-23 19:21:21 - ISY: Variable gem-ST replaced in queue (Val: 121.2
, QS: 108)
2015-11-23 19:21:21 - ISY: Variable gem_chan01-ST replaced in queue (Val: 0, QS: 108)
2015-11-23 19:21:21 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 7338, QS: 108)
2015-11-23 19:21:21 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 99.15, QS: 108)
hmm but then the ISY started getting time outs, dropped off the network (i couldn't get the java app to work) then came back of its own accords.  I don't normally see stuff like that.  But anyways ,log attached.
config.xml
nodelink.log.txt
I also see these in the ISY error log, no idea if related
2015/11/23 19:15:28 System -170001 [Network] Established
2015/11/23 19:17:26 System -170001 [TCP-Conn] -1/-140002, Net Module Rule: 3
2015/11/23 19:17:47 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:17:52 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:17:52 System -170001 [UDSockets] HTTP:32 error:6
2015/11/23 19:17:57 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:17:57 System -170001 [UDSockets] HTTP:32 error:6
2015/11/23 19:18:02 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:18:02 System -170001 [UDSockets] HTTP:32 error:6
2015/11/23 19:18:07 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:18:07 System -170001 [UDSockets] HTTP:32 error:6
2015/11/23 19:18:12 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:18:12 System -170001 [UDSockets] HTTP:32 error:6
2015/11/23 19:18:17 System -170001 [UDSockets] HTTP:30 error:6
2015/11/23 19:18:17 System -170001 [UDSockets] HTTP:32 error:6
2015/11/23 19:18:22 System -170001 [UDSockets] HTTP:28 error:6
Edited by Scyto
attached is my current nodes file for reference
Also for no reason i can determine suddenly the voltage appeared, first time ever,  the ISY portal log shows this:
Device Control Value Time User
n001_test GV2 39 2015/11/23 19:40:00 System 5
n001_test GV3 470620 2015/11/23 19:40:00 System 5
n001_test GV2 40 2015/11/23 19:40:05 System 5
n001_test GV2 44 2015/11/23 19:44:59 System 5
n001_test GV3 470625 2015/11/23 19:44:59 System 5
n001_test GV2 45 2015/11/23 19:45:04 System 5
n001_gem ST 1211 2015/11/23 19:45:39 System 5
ZW024_1 ERR 0 2015/11/23 19:53:15 System 5
ZW024_1 CLITEMP 6810 2015/11/23 19:53:15 System 5
ZW024_1 CLIHUM 43 2015/11/23 19:53:16 System 5
Get Node Info ZWave ZW028_1 2015/11/23 19:54:48 System 5
nodes.xml
Edited by Scyto
No clue on the ISY log - not my area of expertise.
In your NodeLink you're getting (for whatever reason):
ISY Error: Error getting web response from the ISY (The request timed out)
That's what's causing the issue.  Once NodeLink has a send failure, it waits 30s before retrying.  You'll see one of these basically every 30s or so in your log.
Maybe Michel can chime in as to whether the ISY log errors are related.
Can you post a piece of log that captures NodeLink from startup?
here is startup running for 3 minutes.
2015-11-26 11:11:10 - ISY NodeLink Server v0.2.2 started
2015-11-26 11:11:12 - ISY resolved to 192.168.1.97
2015-11-26 11:11:12 - Web config server started (http://192.168.1.118:8090)
2015-11-26 11:11:13 - Auto-Update: Checking for program update...
2015-11-26 11:11:14 - Auto-Update: No web update available
2015-11-26 11:11:14 - ISY: <?xml version="1.0" encoding="UTF-8"?><climate enabled="true" locationId="MID_C5022" rss="http://wx.hamweather.com/?pands=MID_C5022"lastUpdatedTS="2015/11/26 11:10:33"><Temperature>37 °F</Temperature><Temperature_High>37 °F</Temperature_High><Temperature_Low>25 °F</Temperature_Low><Feels_Like>37 °F</Feels_Like><Temperature_Average>26.7 °F</Temperature_Average><Humidity>90 %</Humidity><Pressure>30.53 inHg</Pressure><Dew_Point>34 °F</Dew_Point><Wind_Speed>0 mph</Wind_Speed><Wind_Direction>NE</Wind_Direction><Gust_Speed>1 mph</Gust_Speed><Total_Rain_Today>0 inches</Total_Rain_Today><Light>91 %</Light><Evapotranspiration>-0.0003 inches/day</Evapotranspiration><Irrigation_Requirement>2.7855 inches</Irrigation_Requirement><Water_Deficit_Yesterday>-0.0003 inches</Water_Deficit_Yesterday><Elevation>262 </Elevation><Coverage>0</Coverage><Intensity>0</Intensity><Weather_Condition>0</Weather_Condition><Cloud_Condition>1</Cloud_Condition><Average_Temperature_Tomorrow>37 °F</Average_Temperature_Tomorrow><High_Temperature_Tomorrow>45 °F</High_Temperature_Tomorrow><Low_Temperature_Tomorrow>30 °F</Low_Temperature_Tomorrow><Humidity_Tomorrow>66 %</Humidity_Tomorrow><Wind_Speed_Tomorrow>6 mph</Wind_Speed_Tomorrow><Gust_Speed_Tomorrow>8 mph</Gust_Speed_Tomorrow><Rain_Tomorrow>0 inches</Rain_Tomorrow><Snow_Tomorrow>0 inches</Snow_Tomorrow><Coverage_Tomorrow>0</Coverage_Tomorrow><Intensity_Tomorrow>0</Intensity_Tomorrow><Weather_Condition_Tomorrow>0</Weather_Condition_Tomorrow><Cloud_Condition_Tomorrow>1</Cloud_Condition_Tomorrow><Forecast_Average_Temperature>37 °F</Forecast_Average_Temperature><Forecast_High_Temperature>45 °F</Forecast_High_Temperature><Forecast_Low_Temperature>30 °F</Forecast_Low_Temperature><Forecast_Humidity>66 %</Forecast_Humidity><Forecast_Rain>0 inches</Forecast_Rain><Forecast_Snow>0 inches</Forecast_Snow><Forecast_Coverage>0</Forecast_Coverage><Forecast_Intensity>0</Forecast_Intensity><Forecast_Weather_Condition>0</Forecast_Weather_Condition><Forecast_Cloud_Condition>1</Forecast_Cloud_Condition></climate> (climate)
2015-11-26 11:11:15 - Web Request: /index.htm
2015-11-26 11:11:15 - Web Request: /general.css
2015-11-26 11:11:16 - ISY: Variable test-GV1 added to queue (Val: 11, QS: 1)
2015-11-26 11:11:16 - ISY: Variable test-GV2 added to queue (Val: 11, QS: 2)
2015-11-26 11:11:16 - ISY: Variable test-GV3 added to queue (Val: 474431, QS: 3)
2015-11-26 11:11:16 - ISY: Variable test-GV4 added to queue (Val: 0, QS: 4)
2015-11-26 11:11:16 - ISY: Variable test-GV5 added to queue (Val: 48, QS: 5)
2015-11-26 11:11:16 - ISY: Variable test-GV6 added to queue (Val: 4, QS: 6)
2015-11-26 11:11:16 - ISY: Variable test-GV7 added to queue (Val: 11, QS: 7)
2015-11-26 11:11:16 - ISY: Variable test-GV8 added to queue (Val: 26, QS: 8)
2015-11-26 11:11:16 - ISY: Variable test-GV9 added to queue (Val: 2015, QS: 9)
2015-11-26 11:11:16 - ISY: Variable test-GV10 added to queue (Val: 330, QS: 10)
2015-11-26 11:11:16 - ISY: Variable test-GV11 added to queue (Val: 3, QS: 11)
2015-11-26 11:11:16 - ISY:  (ns/1/nodes/n001_test/report/status/GV1/11/25)
2015-11-26 11:11:16 - ISY:  (ns/1/nodes/n001_test/report/status/GV2/11/25)
2015-11-26 11:11:16 - ISY:  (ns/1/nodes/n001_test/report/status/GV3/474431/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV4/0/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV5/48/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV6/4/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV7/11/47)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV8/26/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV9/2015/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV10/330/25)
2015-11-26 11:11:17 - ISY:  (ns/1/nodes/n001_test/report/status/GV11/3/25)
2015-11-26 11:11:20 - ISY: Variable gem-ST added to queue (Val: 121.5
, QS: 1)
2015-11-26 11:11:20 - ISY: Variable gem_chan01-ST added to queue (Val: 0, QS: 2)
2015-11-26 11:11:20 - ISY: Variable gem_chan01-GV1 added to queue (Val: 1375, QS: 3)
2015-11-26 11:11:20 - ISY: Variable gem_chan01-GV2 added to queue (Val: 256.54, QS: 4)
2015-11-26 11:11:20 - ISY: Variable gem_chan02-ST added to queue (Val: 0, QS: 5)
2015-11-26 11:11:20 - ISY: Variable gem_chan02-GV1 added to queue (Val: 2, QS: 6)
2015-11-26 11:11:20 - ISY: Variable gem_chan02-GV2 added to queue (Val: 2.55, QS: 7)
2015-11-26 11:11:20 - ISY: Variable gem_chan03-ST added to queue (Val: 0, QS: 8)
2015-11-26 11:11:20 - ISY: Variable gem_chan03-GV1 added to queue (Val: 0, QS: 9)
2015-11-26 11:11:20 - ISY: Variable gem_chan03-GV2 added to queue (Val: 128.8, QS: 10)
2015-11-26 11:11:20 - ISY: Variable gem_chan04-ST added to queue (Val: 0, QS: 11)
2015-11-26 11:11:20 - ISY: Variable gem_chan04-GV1 added to queue (Val: 105, QS: 12)
2015-11-26 11:11:20 - ISY: Variable gem_chan04-GV2 added to queue (Val: 12.47, QS: 13)
2015-11-26 11:11:20 - ISY: Variable gem_chan05-ST added to queue (Val: 0, QS: 14)
2015-11-26 11:11:20 - ISY: Variable gem_chan05-GV1 added to queue (Val: 2, QS: 15)
2015-11-26 11:11:20 - ISY: Variable gem_chan05-GV2 added to queue (Val: 1.73, QS: 16)
2015-11-26 11:11:20 - ISY: Variable gem_chan06-ST added to queue (Val: 0, QS: 17)
2015-11-26 11:11:20 - ISY: Variable gem_chan06-GV1 added to queue (Val: 6, QS: 18)
2015-11-26 11:11:20 - ISY: Variable gem_chan06-GV2 added to queue (Val: 1.61, QS: 19)
2015-11-26 11:11:20 - ISY: Variable gem_chan07-ST added to queue (Val: 0, QS: 20)
2015-11-26 11:11:20 - ISY: Variable gem_chan07-GV1 added to queue (Val: 4, QS: 21)
2015-11-26 11:11:20 - ISY: Variable gem_chan07-GV2 added to queue (Val: 3.76, QS: 22)
2015-11-26 11:11:20 - ISY: Variable gem_chan08-ST added to queue (Val: 0, QS: 23)
2015-11-26 11:11:20 - ISY: Variable gem_chan08-GV1 added to queue (Val: 280, QS: 24)
2015-11-26 11:11:20 - ISY: Variable gem_chan08-GV2 added to queue (Val: 9.73, QS: 25)
2015-11-26 11:11:20 - ISY: Variable gem_chan09-ST added to queue (Val: 0, QS: 26)
2015-11-26 11:11:20 - ISY: Variable gem_chan09-GV1 added to queue (Val: 2, QS: 27)
2015-11-26 11:11:20 - ISY: Variable gem_chan09-GV2 added to queue (Val: 0.84, QS: 28)
2015-11-26 11:11:20 - ISY: Variable gem_chan10-ST added to queue (Val: 0, QS: 29)
2015-11-26 11:11:20 - ISY: Variable gem_chan10-GV1 added to queue (Val: 9, QS: 30)
2015-11-26 11:11:20 - ISY: Variable gem_chan10-GV2 added to queue (Val: 1.94, QS: 31)
2015-11-26 11:11:20 - ISY: Variable gem_chan11-ST added to queue (Val: 0, QS: 32)
2015-11-26 11:11:20 - ISY: Variable gem_chan11-GV1 added to queue (Val: 5, QS: 33)
2015-11-26 11:11:20 - ISY: Variable gem_chan11-GV2 added to queue (Val: 3.47, QS: 34)
2015-11-26 11:11:20 - ISY: Variable gem_chan12-ST added to queue (Val: 0, QS: 35)
2015-11-26 11:11:20 - ISY: Variable gem_chan12-GV1 added to queue (Val: 2, QS: 36)
2015-11-26 11:11:20 - ISY: Variable gem_chan12-GV2 added to queue (Val: 0.52, QS: 37)
2015-11-26 11:11:20 - ISY: Variable gem_chan13-ST added to queue (Val: 0, QS: 38)
2015-11-26 11:11:20 - ISY: Variable gem_chan13-GV1 added to queue (Val: 0, QS: 39)
2015-11-26 11:11:20 - ISY: Variable gem_chan13-GV2 added to queue (Val: 0.02, QS: 40)
2015-11-26 11:11:20 - ISY: Variable gem_chan14-ST added to queue (Val: 0, QS: 41)
2015-11-26 11:11:20 - ISY: Variable gem_chan14-GV1 added to queue (Val: 0, QS: 42)
2015-11-26 11:11:20 - ISY: Variable gem_chan14-GV2 added to queue (Val: 0.02, QS: 43)
2015-11-26 11:11:20 - ISY: Variable gem_chan15-ST added to queue (Val: 0, QS: 44)
2015-11-26 11:11:20 - ISY: Variable gem_chan15-GV1 added to queue (Val: 4, QS: 45)
2015-11-26 11:11:20 - ISY: Variable gem_chan15-GV2 added to queue (Val: 0.5, QS: 46)
2015-11-26 11:11:20 - ISY: Variable gem_chan16-ST added to queue (Val: 0, QS: 47)
2015-11-26 11:11:20 - ISY: Variable gem_chan16-GV1 added to queue (Val: 0, QS: 48)
2015-11-26 11:11:20 - ISY: Variable gem_chan16-GV2 added to queue (Val: 0.29, QS: 49)
2015-11-26 11:11:20 - ISY: Variable gem_chan17-ST added to queue (Val: 0, QS: 50)
2015-11-26 11:11:20 - ISY: Variable gem_chan17-GV1 added to queue (Val: 1, QS: 51)
2015-11-26 11:11:20 - ISY: Variable gem_chan17-GV2 added to queue (Val: 1.35, QS: 52)
2015-11-26 11:11:20 - ISY: Variable gem_chan18-ST added to queue (Val: 0, QS: 53)
2015-11-26 11:11:20 - ISY: Variable gem_chan18-GV1 added to queue (Val: 58, QS: 54)
2015-11-26 11:11:20 - ISY: Variable gem_chan18-GV2 added to queue (Val: 9.36, QS: 55)
2015-11-26 11:11:20 - ISY: Variable gem_chan19-ST added to queue (Val: 0, QS: 56)
2015-11-26 11:11:20 - ISY: Variable gem_chan19-GV1 added to queue (Val: 27, QS: 57)
2015-11-26 11:11:20 - ISY: Variable gem_chan19-GV2 added to queue (Val: 1.84, QS: 58)
2015-11-26 11:11:20 - ISY: Variable gem_chan20-ST added to queue (Val: 0, QS: 59)
2015-11-26 11:11:20 - ISY: Variable gem_chan20-GV1 added to queue (Val: 1, QS: 60)
2015-11-26 11:11:20 - ISY: Variable gem_chan20-GV2 added to queue (Val: 0.15, QS: 61)
2015-11-26 11:11:20 - ISY: Variable gem_chan21-ST added to queue (Val: 0, QS: 62)
2015-11-26 11:11:20 - ISY: Variable gem_chan21-GV1 added to queue (Val: 2, QS: 63)
2015-11-26 11:11:20 - ISY: Variable gem_chan21-GV2 added to queue (Val: 0.22, QS: 64)
2015-11-26 11:11:20 - ISY: Variable gem_chan22-ST added to queue (Val: 0, QS: 65)
2015-11-26 11:11:20 - ISY: Variable gem_chan22-GV1 added to queue (Val: 1, QS: 66)
2015-11-26 11:11:20 - ISY: Variable gem_chan22-GV2 added to queue (Val: 0.15, QS: 67)
2015-11-26 11:11:20 - ISY: Variable gem_chan23-ST added to queue (Val: 0, QS: 68)
2015-11-26 11:11:20 - ISY: Variable gem_chan23-GV1 added to queue (Val: 1, QS: 69)
2015-11-26 11:11:20 - ISY: Variable gem_chan23-GV2 added to queue (Val: 0.14, QS: 70)
2015-11-26 11:11:20 - ISY: Variable gem_chan24-ST added to queue (Val: 0, QS: 71)
2015-11-26 11:11:20 - ISY: Variable gem_chan24-GV1 added to queue (Val: 53, QS: 72)
2015-11-26 11:11:20 - ISY: Variable gem_chan24-GV2 added to queue (Val: 5.79, QS: 73)
2015-11-26 11:11:20 - ISY: Variable gem_chan25-ST added to queue (Val: 0, QS: 74)
2015-11-26 11:11:20 - ISY: Variable gem_chan25-GV1 added to queue (Val: 115, QS: 75)
2015-11-26 11:11:20 - ISY: Variable gem_chan25-GV2 added to queue (Val: 1.38, QS: 76)
2015-11-26 11:11:20 - ISY: Variable gem_chan26-ST added to queue (Val: 0, QS: 77)
2015-11-26 11:11:20 - ISY: Variable gem_chan26-GV1 added to queue (Val: 0, QS: 78)
2015-11-26 11:11:20 - ISY: Variable gem_chan26-GV2 added to queue (Val: 0.13, QS: 79)
2015-11-26 11:11:20 - ISY: Variable gem_chan27-ST added to queue (Val: 0, QS: 80)
2015-11-26 11:11:20 - ISY: Variable gem_chan27-GV1 added to queue (Val: 3, QS: 81)
2015-11-26 11:11:20 - ISY: Variable gem_chan27-GV2 added to queue (Val: 1.84, QS: 82)
2015-11-26 11:11:20 - ISY: Variable gem_chan28-ST added to queue (Val: 0, QS: 83)
2015-11-26 11:11:20 - ISY: Variable gem_chan28-GV1 added to queue (Val: 26, QS: 84)
2015-11-26 11:11:20 - ISY: Variable gem_chan28-GV2 added to queue (Val: 2.86, QS: 85)
2015-11-26 11:11:20 - ISY: Variable gem_chan29-ST added to queue (Val: 0, QS: 86)
2015-11-26 11:11:20 - ISY: Variable gem_chan29-GV1 added to queue (Val: 461, QS: 87)
2015-11-26 11:11:20 - ISY: Variable gem_chan29-GV2 added to queue (Val: 42.19, QS: 88)
2015-11-26 11:11:20 - ISY: Variable gem_chan30-ST added to queue (Val: 0, QS: 89)
2015-11-26 11:11:20 - ISY: Variable gem_chan30-GV1 added to queue (Val: 154, QS: 90)
2015-11-26 11:11:20 - ISY: Variable gem_chan30-GV2 added to queue (Val: 16.83, QS: 91)
2015-11-26 11:11:20 - ISY: Variable gem_chan31-ST added to queue (Val: 0, QS: 92)
2015-11-26 11:11:20 - ISY: Variable gem_chan31-GV1 added to queue (Val: 7, QS: 93)
2015-11-26 11:11:20 - ISY: Variable gem_chan31-GV2 added to queue (Val: 0.82, QS: 94)
2015-11-26 11:11:20 - ISY: Variable gem_chan32-ST added to queue (Val: 0, QS: 95)
2015-11-26 11:11:20 - ISY: Variable gem_chan32-GV1 added to queue (Val: 0, QS: 96)
2015-11-26 11:11:20 - ISY: Variable gem_chan32-GV2 added to queue (Val: 0.03, QS: 97)
2015-11-26 11:11:20 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.5
/72)
2015-11-26 11:11:23 - Web Request: /index.htm
2015-11-26 11:11:23 - Web Request: /general.css
2015-11-26 11:11:31 - ISY: Variable test-GV3 added to queue (Val: 474432, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem-ST replaced in queue (Val: 121.6
, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1386, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.55, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 278, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 62, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 116, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 473, QS: 98)
2015-11-26 11:11:35 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 150, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 4, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 281, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 61, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan22-GV1 replaced in queue (Val: 0, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 115, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 464, QS: 98)
2015-11-26 11:11:50 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 155, QS: 98)
2015-11-26 11:11:51 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.6
/72)
2015-11-26 11:12:01 - ISY: Variable test-GV2 added to queue (Val: 12, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem-ST replaced in queue (Val: 121.7
, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1380, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.56, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan05-GV1 replaced in queue (Val: 3, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan06-GV1 replaced in queue (Val: 6, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 279, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan08-GV2 replaced in queue (Val: 9.74, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan20-GV2 replaced in queue (Val: 0.16, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 114, QS: 99)
2015-11-26 11:12:05 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 477, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem-ST replaced in queue (Val: 121.8
, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1364, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.57, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan02-GV1 replaced in queue (Val: 3, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan05-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 286, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 60, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 115, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 466, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 42.2, QS: 99)
2015-11-26 11:12:20 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 153, QS: 99)
2015-11-26 11:12:20 - Web Request: /index.htm
2015-11-26 11:12:20 - Web Request: /general.css
2015-11-26 11:12:22 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.8
/72)
2015-11-26 11:12:26 - Web Request: /index.htm
2015-11-26 11:12:26 - Web Request: /general.css
2015-11-26 11:12:31 - ISY: Variable test-GV3 replaced in queue (Val: 474433, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem-ST replaced in queue (Val: 121.7
, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1357, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan02-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan05-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 288, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan09-GV2 replaced in queue (Val: 0.85, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan22-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 113, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 459, QS: 99)
2015-11-26 11:12:35 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 154, QS: 99)
2015-11-26 11:12:45 - Web Request: /index.htm
2015-11-26 11:12:45 - Web Request: /general.css
2015-11-26 11:12:50 - ISY: Variable gem-ST replaced in queue (Val: 122.0
, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1358, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.58, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan02-GV1 replaced in queue (Val: 3, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 61, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 114, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 458, QS: 99)
2015-11-26 11:12:50 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 153, QS: 99)
2015-11-26 11:12:52 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/122.0
/72)
2015-11-26 11:13:01 - ISY: Variable test-GV2 replaced in queue (Val: 13, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1361, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan02-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 291, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 26, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 113, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 459, QS: 99)
2015-11-26 11:13:05 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 154, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem-ST replaced in queue (Val: 122.1
, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1360, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.59, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan05-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 290, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan18-GV2 replaced in queue (Val: 9.37, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 27, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 460, QS: 99)
2015-11-26 11:13:20 - ISY: Variable gem_chan30-GV2 replaced in queue (Val: 16.84, QS: 99)
2015-11-26 11:13:23 - Web Request: /index.htm
2015-11-26 11:13:23 - Web Request: /general.css
2015-11-26 11:13:23 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/122.1
/72)
2015-11-26 11:13:31 - ISY: Variable test-GV3 replaced in queue (Val: 474434, QS: 99)
2015-11-26 11:13:33 - Web Request: /index.htm
2015-11-26 11:13:33 - Web Request: /general.css
2015-11-26 11:13:35 - ISY: Variable gem-ST replaced in queue (Val: 121.7
, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1368, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan05-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 293, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 1, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 58, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan21-GV1 replaced in queue (Val: 2, QS: 99)
2015-11-26 11:13:35 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 462, QS: 99)
2015-11-26 11:13:44 - Web Request: /index.htm
2015-11-26 11:13:44 - Web Request: /general.css
2015-11-26 11:13:50 - ISY: Variable gem-ST replaced in queue (Val: 121.9
, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1353, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.6, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 290, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 60, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 26, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 115, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 456, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan29-GV2 replaced in queue (Val: 42.21, QS: 99)
2015-11-26 11:13:50 - ISY: Variable gem_chan30-GV1 replaced in queue (Val: 155, QS: 99)
2015-11-26 11:13:54 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.9
/72)
2015-11-26 11:14:02 - ISY: Variable test-GV2 replaced in queue (Val: 14, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem-ST replaced in queue (Val: 121.7
, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan01-GV1 replaced in queue (Val: 1376, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan01-GV2 replaced in queue (Val: 256.61, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan02-GV1 replaced in queue (Val: 3, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan04-GV1 replaced in queue (Val: 108, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan08-GV1 replaced in queue (Val: 291, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan08-GV2 replaced in queue (Val: 9.75, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan10-GV1 replaced in queue (Val: 10, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan17-GV1 replaced in queue (Val: 0, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan18-GV1 replaced in queue (Val: 58, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan19-GV1 replaced in queue (Val: 27, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan24-GV1 replaced in queue (Val: 54, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan25-GV1 replaced in queue (Val: 114, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan28-GV1 replaced in queue (Val: 28, QS: 99)
2015-11-26 11:14:05 - ISY: Variable gem_chan29-GV1 replaced in queue (Val: 461, QS: 99)
2015-11-26 11:14:15 - Web Request: /index.htm
basically  only the voltage gets written for the gem node - no data is written to the child nodes.  All the fields are populated on the test node on nodelink startup.  But after the first write no more updates are done and the gem channel nodes never get written too.
Edited by Scyto
Your issue is:
2015-11-26 11:11:20 - ISY Error: The remote server returned an error: (404) OK. (ns/1/nodes/n001_gem/report/status/ST/121.5/72)
Nothing else will write because you error out, it has nothing to do with gem/data/child nodes.  I don't know why it's giving a 404.  Are you running 5.0.2?  This was a bug in 5.0.1
