Python control of MyQ Garage Doors
Hi Jimbo and xKing,
Deleting the myqtoken.json file worked as long as the myq-garage.log file is under pi ownership. I am not sure what is triggering this to change. This morning when i checked the ownership of the file, it is back to root again. Could you help explain what is causing this to keep reverting back to root? Also, could you explain how the myqtoken.json file got created if it is not needed? I just want to understand kinda understand this more.
Thanks again for all your help.
Larry
Perhaps you invoking the script with dscServer which you run as root?... Make sure to run it as pi (you may need to change it's config.xml ownership to pi as well)
I would recommend against running anything which is not a system service as root.
Hi xKing,
I checked it again since it stopped working again. The myq-garage.log seems like it is retaining the ownership as pi and NOT root. However, the myqtoken.json must be deleted each time when it stops working. I am not sure why this file is causing it to stop working. Any ideas?
Hi xKing,
Yes you are right... the myqtoken.json is getting root ownership because the config.xml for Nodelink is set as root ownership. I just changed that to pi as well the myq-garage.log and now everytime the myqtoken.json is created.. it is being created as pi ownership. I will continue to monitor it. I disabled the cron job that I was running to delete the file and see how this one will go.
Thanks again
Hi xKing,
Here is the result
pi@raspberrypi:~ $ ps -ef | grep mono
root       978     1  5 Feb26 ?        01:44:16 mono /home/pi/node/NodeLink.exe
pi        9439  9392  0 20:15 pts/0    00:00:00 grep --color=auto mono
Looks like the NodeLink.exe is showing as root. how do I fix that.
Larry
Hi xKing,
The Nodelink run on mono. The program is executed as follows:
mono ~/node/NodeLink.exe
However, I added this line on the rc.local so that when I reboot the raspberry pi, it will automatically launch the program.
mono /home/pi/node/NodeLink.exe &
Hope you can help me change the ownership from this info. Thanks again.
Thanks xKing. I will give this a try when I get home tonight.
Thanks for your help. I've learned so much from you :)
Hi xKing,
I changed the line in my rc.local per your instructions. However, it is still not working. The file still needs to be deleted in order for the command to respond. Is it bad to run contab -e every 1 min to delete the file? Please advise.
root      1237     1  0 Feb28 ?        00:00:00 su pi -c mono /home/pi/node/NodeLink.exe
pi        1244  1237  5 Feb28 ?        01:11:12 mono /home/pi/node/NodeLink.exe
pi        3283  3267  0 20:04 pts/0    00:00:00 grep --color=auto mono
do you mean /tmp/myqtoken.json? Is it getting created as root?
can you show ls -la /tmp at that time?
do you call myq-garage from anywhere else except the nodeLink? maybe crontab or something? you'll need to find out what calls script as root.
Hi xKing,
Here is the result from the ls -la /tmp
root@raspberrypi:~# ls -la /tmp
total 624
drwxrwxrwt 14 root root   4096 Mar  3 18:28 .
drwxr-xr-x 21 root root   4096 Oct 23 15:26 ..
-rw-r--r--  1 pi   pi   566459 Mar  3 18:28 cloud-print-connector
srwxr-xr-x  1 pi   pi        0 Feb 28 21:33 cloud-print-connector-monitor.sock
drwx------  2 pi   pi     4096 Feb 28 21:32 dhcpcd-(null)
drwxrwxrwt  2 root root   4096 Feb 28 21:32 .font-unix
drwxrwxrwt  2 root root   4096 Feb 28 21:32 .ICE-unix
srwxr-xr-x  1 pi   pi        0 Feb 28 21:32 .menu-cached-:0-pi
-rw-------  1 pi   pi       93 Mar  3 18:28 myqtoken.json
srwxr-xr-x  1 pi   pi        0 Feb 28 21:32 .pcmanfm-socket--0-pi
drwx------  2 root root   4096 Feb 28 21:32 pulse-PKdhtXMmr18n
drwx------  2 pi   pi     4096 Feb 28 21:32 ssh-oqIsvg9tmD9E
drwx------  2 pi   pi     4096 Feb 28 21:32 ssh-Yo2MOcnXwp3g
drwx------  3 root root   4096 Feb 28 21:32 systemd-private-f8bc8ad405b641e5a97c881569d15787-colord.service-Eihu69
drwx------  3 root root   4096 Mar  3 07:35 systemd-private-f8bc8ad405b641e5a97c881569d15787-cups.service-gDB9XS
drwx------  3 root root   4096 Feb 28 21:32 systemd-private-f8bc8ad405b641e5a97c881569d15787-rtkit-daemon.service-B5pspF
drwxrwxrwt  2 root root   4096 Feb 28 21:32 .Test-unix
-r--r--r--  1 root root     11 Feb 28 21:32 .X0-lock
drwxrwxrwt  2 root root   4096 Feb 28 21:32 .X11-unix
drwxrwxrwt  2 root root   4096 Feb 28 21:32 .XIM-unix
it doesn't look like the file is getting created as root anymore. Another observation I noticed is that the myqtoken.json file only gets created as soon as I make a call to myq-garage.py from the ISY Network Resource. My Network Resource setting in ISY is as follows:
Command Type: tcp
Host: <isy_iip_address>
Port: <nodelink_port_nbr>
Mode: C Escaped
When I run the network resource from ISY, it will communicate with the NodeLink Relay Server which will call the myq.garage.py to run with proper arguments [open/close/status] [doorname]. For now, I created this shell script
#!/bin/sh
file=/tmp/myqtoken.json
if [ -f "$file" ] ; then
   rm -f "$file"
fi
and setup crontab -e to * * * * * /home/pi/node/del_myqtoken.sh to delete the file if it exist. This cron is running every minute to see if there is a file there.
I know that this isn't really fixing a root cause, but for now, it is working. However, any guidance you may have to identify the root cause is greatly appreciated.
If the file exists, the garage door will not respond regardless if the command is run from the Terminal or Network Resource in ISY. I am basically getting this error message:
2017-03-01 18:21:50,377 ERROR    Traceback (most recent call last):
2017-03-01 18:21:50,377 ERROR      File "/home/pi/node/myq-garage.py", line 407, in <module>
2017-03-01 18:21:50,378 ERROR    gdoor_main()
2017-03-01 18:21:50,378 ERROR      File "/home/pi/node/myq-garage.py", line 396, in gdoor_main
2017-03-01 18:21:50,379 ERROR    print(doorname + ' not found in available doors.')
2017-03-01 18:21:50,379 ERROR    UnboundLocalError
2017-03-01 18:21:50,379 ERROR    :
2017-03-01 18:21:50,379 ERROR    local variable 'doorname' referenced before assignment
Hi xKing,
Please disregard that error message that i provided in the above comment. I just replicated the issue and actually the commands from the either the Terminal or Network Resource in ISY will not respond to the garage door. I just looked at the log and all it shows is this. Not sure what the means but in order for the garage door to respond to the commands, the token file must be deleted. Somehow the token seems to not able to get a new token when it expires.
2017-03-03 20:53:55,261 INFO     ==================================STARTED==================================
2017-03-03 20:54:37,143 INFO     ==================================STARTED==================================
2017-03-03 20:55:13,465 INFO     ==================================STARTED==================================
Hm... does it happen immediately or after some time? Like 30 minutes?
Maybe TOKENTTL value of 60 is too big, try setting it to 30?
I will look at the script again, may need to enhance it to re-fetch the token on 1st error with the saved one.
Edited by xKing
I noticed that it stops responding between 10 to 15 minutes after the myqtoken.json file was created. For sure its good at least 8 minutes.
OMG xKing... after changing the TOKENTTL to 8, it is now working without deleting the file. I've been checking it every minute to see where it will break.. but so far, its been 26 minutes since myqtoken.json file was created and still working. Just for my understanding, do you know why changing it to 8 made a difference?
Well, if TOKENTTL is 8 minutes - it will save the auth token and only use it for 8 minutes, after that it will just fetch a new one. Since MyQ web site does not return token validity period - we could only assume how long it's good for... Apparently 60 is way too much. We'll need to correct token caching logic a bit.
