version 0.2.4 rc.local issue?
io_guy,
I'm sorry to always be the one who has problems.  :)
I tried updating to version 0.2.4 of NodeLink, but I can't get it to work on my RPi to automatically start with the rc.local file.  The previous versions worked fine, but for some reason, this one won't start automatically.  It does work if I hit "restart NodeLink" button on the web interface, but if I reboot the RPi, it doesn't seem to be running (or at least, I can't get to it via the same IP:port address that worked just before I restarted.
Is it some issue with mono?  Not sure how to debug this one.
Same rc.local file that worked with v0.2.3, with the line:
sudo mono ~/node/NodeLink.exe &
Filename is the same, with correct capitals for N and L in the sudo mono line
If I go back to v0.2.3, it works fine.
Thanks in advance!
Edited by Toddimus
Please PM me your config.xml.
On reboot do you need the NodeLink process running?
ps ax | grep NodeLink
Do you see anything in your system log (in /var/log)?
