Admin URL in Portal
How do I access the admin console via Portal? I need the URL .. I would assume it should be in the drop down under Tools but its not there.. what am i missing?
Many thanks
On the 'Select Tools' menu, select 'ISY Information'. It will pop-up.
It uses JavaScript, so if you use an ad blocker you may have to whitelist my.ISY.io.
Michael.
