Linking a 2672(InsteonLED bulb) to a Dimming KPL ?
I have a Dimming KPL(2334) wired to a set of hall sconces. In a separate adjacent hallway, I have a ceiling fixture (not wired to the KPL) with an Insteon 2672 LED bulb.
I have set up a scene were the main KPL key pad brings up the sconces to 12% and also brings the 2672 LED bulb in the adjacent hall to 12%. Everything works fine !
Am I "OK" with this ?
I understand not to wire a dimmer to the 2672 LED bulb. What I'm fuzzy on is how the bulb, as a responding scene member, is being powered up/controlled when the key on the dimmer is pressed. Also, local dimming of both the bulb and the sconces works fine (and in tandem) when the main key is held in, which is precisely what I desire. I just want to be safe with this.
The Insteon LED bulb is functioning as it should. Not to worry B)
