Kinda Dead IOLinc 2450 v.36
hart2hart
I've got 2 of them.  They see Insteon commands for on/off by seeing LED go on and off but relay does not activate.  They see that sensor has been closed by LED but do not send Insteon.  Anyone fix these?  For postage I'll give away.
  • 4 weeks later...
Okay. No one wants them . Just curious ... are bad capacitors likely culprit here? I might fix one to just to see if possible but wouldn't use it for fear of issues if device ever resulted in insurance claim -- Regardless of underlying cause.
Edited by hart2hart
Does the relay close if you send a direct command to the relay.
Edited by stusviews
Symptoms indicate a hardware failure.
Relay On/Off LED changing state but the relay not working. Could be a defective relay or circuit driving it.
Sensor LED On/Off but no detected change sent back.. Also sounds like a hardware failure.
Edited by Brian H
      38k
      379.4k
