Cannot determine Insteon Engine
Trying to add a just bought 2334-232 from the Smarthome black friday/cyber monday sale.
Getting the message as attached in the photo.
The logs show the motion sensors getting hammered by some guests so those can be ignored.
Sat 12/12/2015 02:50:34 PM : [3b 8f 4a    ] Added to list of devices to link to ISY
Sat 12/12/2015 02:50:34 PM : [iNST-TX-I1  ] 02 62 3B 8F 4A 0F 0D 00
Sat 12/12/2015 02:50:34 PM : [iNST-ACK    ] 02 62 3B.8F.4A 0F 0D 00 06                 (00)
Sat 12/12/2015 02:50:34 PM : [iNST-SRX    ] 02 50 3B.8F.4A 19.72.DE A7 0D FF           (FF)
Sat 12/12/2015 02:50:34 PM : [std-Direct Nack] 3B.8F.4A-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 12/12/2015 02:50:34 PM : [iNST-TX-I2CS] 02 62 3B 8F 4A 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Sat 12/12/2015 02:50:35 PM : [iNST-ACK    ] 02 62 3B.8F.4A 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Sat 12/12/2015 02:50:38 PM : [iNST-SRX    ] 02 50 23.3C.D4 19.72.DE 42 11 01    LTONRR (01)
Sat 12/12/2015 02:50:38 PM : [std-Cleanup ] 23.3C.D4-->ISY/PLM Group=1, Max Hops=2, Hops Left=0
Sat 12/12/2015 02:50:38 PM : [D2D EVENT   ] Event [23 3C D4 1] [DON] [0] uom=0 prec=-1
Sat 12/12/2015 02:50:38 PM : [  23 3C D4 1]      DON   0
Sat 12/12/2015 02:50:38 PM : [D2D EVENT   ] Event [23 3C D4 1] [sT] [255] uom=0 prec=-1
Sat 12/12/2015 02:50:38 PM : [  23 3C D4 1]       ST 255
Sat 12/12/2015 02:50:39 PM : [iNST-SRX    ] 02 50 23.3C.D4 19.72.DE 47 11 01    LTONRR (01)
Sat 12/12/2015 02:50:39 PM : [std-Cleanup ] 23.3C.D4-->ISY/PLM Group=1, Max Hops=3, Hops Left=1
Sat 12/12/2015 02:50:39 PM : [iNST-DUP    ] Previous message ignored.
Sat 12/12/2015 02:50:40 PM : [iNST-SRX    ] 02 50 23.3C.D4 19.72.DE 47 11 01    LTONRR (01)
Sat 12/12/2015 02:50:40 PM : [std-Cleanup ] 23.3C.D4-->ISY/PLM Group=1, Max Hops=3, Hops Left=1
Sat 12/12/2015 02:50:40 PM : [iNST-DUP    ] Previous message ignored.
Sat 12/12/2015 02:50:40 PM : [iNST-SRX    ] 02 50 23.3C.D4 11.01.01 C7 06 00           (00)
Sat 12/12/2015 02:50:40 PM : [std-Group   ] 23.3C.D4-->11.01.01, Max Hops=3, Hops Left=1
Sat 12/12/2015 02:50:40 PM : [iNST-INFO   ] Previous message ignored.
Sat 12/12/2015 02:50:41 PM : [iNST-SRX    ] 02 50 23.3C.D4 11.01.01 C7 06 00           (00)
Sat 12/12/2015 02:50:41 PM : [std-Group   ] 23.3C.D4-->11.01.01, Max Hops=3, Hops Left=1
Sat 12/12/2015 02:50:41 PM : [iNST-INFO   ] Previous message ignored.
Sat 12/12/2015 02:50:41 PM : [iNST-SRX    ] 02 50 23.3C.D4 00.00.01 C3 13 01    LTOFFRR(01)
Sat 12/12/2015 02:50:41 PM : [std-Group   ] 23.3C.D4-->Group=1, Max Hops=3, Hops Left=0
Sat 12/12/2015 02:50:41 PM : [D2D EVENT   ] Event [23 3C D4 1] [DOF] [1] uom=0 prec=-1
Sat 12/12/2015 02:50:41 PM : [  23 3C D4 1]      DOF   1
Sat 12/12/2015 02:50:41 PM : [D2D EVENT   ] Event [23 3C D4 1] [sT] [0] uom=0 prec=-1
Sat 12/12/2015 02:50:41 PM : [  23 3C D4 1]       ST   0
Sat 12/12/2015 02:50:41 PM : [iNST-DUP    ] Previous message ignored.
Sat 12/12/2015 02:50:42 PM : [iNST-SRX    ] 02 50 23.3C.D4 00.00.01 C7 13 01    LTOFFRR(01)
Sat 12/12/2015 02:50:42 PM : [std-Group   ] 23.3C.D4-->Group=1, Max Hops=3, Hops Left=1
Sat 12/12/2015 02:50:42 PM : [D2D EVENT   ] Event [23 3C D4 1] [DOF] [1] uom=0 prec=-1
Sat 12/12/2015 02:50:42 PM : [  23 3C D4 1]      DOF   1
Sat 12/12/2015 02:50:50 PM : [iNST-SRX    ] 02 50 23.C7.40 00.00.01 CB 13 00    LTOFFRR(00)
Sat 12/12/2015 02:50:50 PM : [std-Group   ] 23.C7.40-->Group=1, Max Hops=3, Hops Left=2
Sat 12/12/2015 02:50:50 PM : [D2D EVENT   ] Event [23 C7 40 1] [DOF] [0] uom=0 prec=-1
Sat 12/12/2015 02:50:50 PM : [  23 C7 40 1]      DOF   0
Sat 12/12/2015 02:50:50 PM : [D2D-CMP 000B] CTL [23 C7 40 1] DOF op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Sat 12/12/2015 02:50:50 PM : [D2D EVENT   ] Event [23 C7 40 1] [sT] [0] uom=0 prec=-1
Sat 12/12/2015 02:50:50 PM : [  23 C7 40 1]       ST   0
Sat 12/12/2015 02:50:50 PM : [iNST-SRX    ] 02 50 23.C7.40 19.72.DE 41 13 01    LTOFFRR(01)
Sat 12/12/2015 02:50:50 PM : [std-Cleanup ] 23.C7.40-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Sat 12/12/2015 02:50:50 PM : [iNST-DUP    ] Previous message ignored.
Sat 12/12/2015 02:50:51 PM : [iNST-TX-I2CS] 02 62 3B 8F 4A 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Sat 12/12/2015 02:50:51 PM : [iNST-ACK    ] 02 62 3B.8F.4A 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Sat 12/12/2015 02:51:00 PM : [iNST-TX-I2CS] 02 62 3B 8F 4A 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Sat 12/12/2015 02:51:00 PM : [iNST-ACK    ] 02 62 3B.8F.4A 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Sat 12/12/2015 02:51:04 PM : [3B 8F 4A 0  ] Failed to add device, reason 3
Sat 12/12/2015 02:51:04 PM : [All         ] Writing 0 bytes to devices
Sat 12/12/2015 02:51:13 PM : [iNST-SRX    ] 02 50 21.59.9E 00.00.01 CB 13 01    LTOFFRR(01)
Sat 12/12/2015 02:51:13 PM : [std-Group   ] 21.59.9E-->Group=1, Max Hops=3, Hops Left=2
Sat 12/12/2015 02:51:13 PM : [D2D EVENT   ] Event [21 59 9E 1] [DOF] [1] uom=0 prec=-1
Sat 12/12/2015 02:51:13 PM : [  21 59 9E 1]      DOF   1
Sat 12/12/2015 02:51:13 PM : [D2D EVENT   ] Event [21 59 9E 1] [sT] [0] uom=0 prec=-1
Sat 12/12/2015 02:51:13 PM : [  21 59 9E 1]       ST   0
Sat 12/12/2015 02:51:13 PM : [D2D-CMP 0015] STS [21 59 9E 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=255 uom=0 prec=-1) --> false
Sat 12/12/2015 02:51:14 PM : [iNST-SRX    ] 02 50 21.59.9E 00.00.01 CB 13 01    LTOFFRR(01)
Sat 12/12/2015 02:51:14 PM : [std-Group   ] 21.59.9E-->Group=1, Max Hops=3, Hops Left=2
Sat 12/12/2015 02:51:14 PM : [iNST-DUP    ] Previous message ignored.
Sat 12/12/2015 02:50:42 PM : [std-Group   ] 23.3C.D4-->Group=1, Max Hops=3, Hops Left=1 <-- Motion Sensor
Reason 3 = unable to communicate
Looks to me your comms are bad for whatever reason (noise?)  Motion sensor also has comm issues.
When I add wired devices I've now developed a method of hooking it up first to a 3 wire extension cable and plugging it into the same outlet as the PLM.
Jon...
I agree with jerlands that comm is marginal.   Also the flood of Motion Sensor messages makes the comm more difficult.   Here is what the first part of the trace should look like when adding an I2CS Keypad.  The message activity in Red is missing in your trace.
Sat 12/12/2015 07:46:07 PM : [33 14 c5    ] Added to list of devices to link to ISY
Sat 12/12/2015 07:46:07 PM : [iNST-TX-I1  ] 02 62 33 14 C5 0F 0D 00
Sat 12/12/2015 07:46:07 PM : [iNST-ACK    ] 02 62 33.14.C5 0F 0D 00 06                 (00)
Sat 12/12/2015 07:46:07 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B AB 0D FF           (FF)
Sat 12/12/2015 07:46:07 PM : [std-Direct Nack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:07 PM : [iNST-TX-I2CS] 02 62 33 14 C5 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Sat 12/12/2015 07:46:07 PM : [iNST-ACK    ] 02 62 33.14.C5 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Sat 12/12/2015 07:46:08 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 09 01    LNK-ON (01)
Sat 12/12/2015 07:46:08 PM : [std-Direct Ack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:08 PM : [LNK-BGN     ] 02 64 01 00 06
Sat 12/12/2015 07:46:09 PM : [LNK-STAT    ] 02 53 M(01) gid=00 33.14.C5 0141 43
Sat 12/12/2015 07:46:09 PM : [iNST-TX-I1  ] 02 62 33 14 C5 0F 0D 00
Sat 12/12/2015 07:46:09 PM : [LNK-END     ] 02 65 06
Sat 12/12/2015 07:46:09 PM : [std MH      ] Unexpected Ack imCmd=65 cmd1= 0xC5
Sat 12/12/2015 07:46:09 PM : [iNST-ACK    ] 02 62 33.14.C5 0F 0D 00 06                 (00)
Sat 12/12/2015 07:46:09 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 0D 02           (02)
Sat 12/12/2015 07:46:09 PM : [std-Direct Ack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:14 PM : [iNST-TX-I1  ] 02 62 33 14 C5 0F 0D 00
Sat 12/12/2015 07:46:14 PM : [iNST-ACK    ] 02 62 33.14.C5 0F 0D 00 06                 (00)
Sat 12/12/2015 07:46:14 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 0D 02           (02)
Sat 12/12/2015 07:46:14 PM : [std-Direct Ack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:14 PM : [iNST-TX-I1  ] 02 62 33 14 C5 0F 10 00
Sat 12/12/2015 07:46:14 PM : [iNST-ACK    ] 02 62 33.14.C5 0F 10 00 06          ID-REQ (00)
Sat 12/12/2015 07:46:14 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 10 00    ID-REQ (00)
Sat 12/12/2015 07:46:15 PM : [iNST-SRX    ] 02 50 33.14.C5 01.41.43 8B 01 73           (73)
Sat 12/12/2015 07:46:15 PM : [std-Broadcast] 33.14.C5-->01.41.43, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:15 PM : [33 14 C5 0  ] Calibrating engine version
Sat 12/12/2015 07:46:15 PM : [iNST-TX-I2CS] 02 62 33 14 C5 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sat 12/12/2015 07:46:15 PM : [iNST-ACK    ] 02 62 33.14.C5 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Sat 12/12/2015 07:46:15 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 2F 00           (00)
Sat 12/12/2015 07:46:15 PM : [std-Direct Ack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:16 PM : [iNST-ERX    ] 02 51 33 14 C5 22 80 0B 11 2F 00 00 01 0F FF 00 AA 00 22 80 0B 00 1C 01 4E
Sat 12/12/2015 07:46:16 PM : [Ext-Direct  ] 33.14.C5-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 12/12/2015 07:46:16 PM : [33 14 C5 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Sat 12/12/2015 07:46:16 PM : [33 14 C5 1  ] Start : Adding device to ISY
Sat 12/12/2015 07:46:16 PM : [33 14 C5 1  ] Finish : Adding device to ISY was Successful
Sat 12/12/2015 07:46:16 PM : [33 14 C5 1  ] Link    0 : 0FF8 [A20022800BFF1F01] Saving  [A20022800BFF1F01]
Sat 12/12/2015 07:46:16 PM : [33 14 C5 1  ] Link    1 : 0FF0 [E20122800B010001] Saving  [E20122800B010001]
Sat 12/12/2015 07:46:17 PM : [iNST-TX-I2CS] 02 62 33 14 C5 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1
Sat 12/12/2015 07:46:17 PM : [iNST-ACK    ] 02 62 33.14.C5 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06        (00)
Sat 12/12/2015 07:46:17 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 2E 00           (00)
Sat 12/12/2015 07:46:17 PM : [std-Direct Ack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:17 PM : [iNST-ERX    ] 02 51 33 14 C5 22 80 0B 11 2E 00 01 01 00 00 20 20 1C FE 05 00 00 00 00 00
Sat 12/12/2015 07:46:17 PM : [Ext-Direct  ] 33.14.C5-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 12/12/2015 07:46:17 PM : [D2D EVENT   ] Event [33 14 C5 1] [OL] [255] uom=0 prec=-1
Sat 12/12/2015 07:46:17 PM : [  33 14 C5 1]       OL 255
Sat 12/12/2015 07:46:18 PM : [D2D EVENT   ] Event [33 14 C5 1] [RR] [28] uom=0 prec=-1
Sat 12/12/2015 07:46:18 PM : [  33 14 C5 1]       RR  28
Sat 12/12/2015 07:46:18 PM : [iNST-TX-I1  ] 02 62 33 14 C5 0F 1F 00
Sat 12/12/2015 07:46:18 PM : [iNST-ACK    ] 02 62 33.14.C5 0F 1F 00 06          GOF    (FLAGS)
Sat 12/12/2015 07:46:18 PM : [iNST-SRX    ] 02 50 33.14.C5 22.80.0B 2B 1F 08    GOF    (08)
Sat 12/12/2015 07:46:18 PM : [std-Direct Ack] 33.14.C5-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 12/12/2015 07:46:18 PM : [33 14 C5 2  ] Start : Adding device to ISY
Sat 12/12/2015 07:46:18 PM : [33 14 C5 2  ] Finish : Adding device to ISY was Successful
Suggest connecting KPL to extension cord and plug into PLM circuit for test purposes.
Edited by LeeG
Thank you gentlemen.  I just ran the same add device this morning with no guests and it ran perfectly with 2 hops remaining.
Also going to adjust the one motion sensor to timeout instead of transmit continuously, I have to surmise that the traffic was too much with the motion sensor transmitting continuously while the guests were here.
Now off to diagnose the front porch, it always turns off, just won't turn on.  Changed the switch, changed the load, no difference.  Won't reliably answer a query either.  Will dump a filter on some items that might be before the switch and plug in my x10 meter to see what the outlet that is on the same feed as this switch says the signal is.
There are multiple dual band items within a few feet.
The motion sensor does not transmit continuously. The motion sensor transmits momentarily (twice) each time motion is sensed if "As motion is sensed" is checked and momentarily (twice) only after the time out if "As motion is sensed" is not checked and motion continues. Changing the time out duration has no effect on that function.
Simply installing a filter is useless unless you have definitely shown the the item is the cause of communication difficulty. You can do that by unplugging or disconnecting the suspect item and observing the result. BTW, just turning something off is inadequate, it must be unplugged or disconnected.
Edited by stusviews
I have a motion sensor that would beg to differ with you, it blinks it's red light for a good 20 seconds after motion, and this switch that is giving me trouble has blink on traffic turned on.  It just starting blinking for 20 seconds or so at a time, gotta wonder..
The level 3 console will show no activity while the switch is blinking.
The circuit I am going to filter has the tivo on it as well, don't like to mess with the power much on those.
Normally, fast blinking indicates the MS is low on battery power, can not communicate either because of noise or a broken link to a device no longer in the network or not powered.
The last fast blink is when remote programming is active.
This seems to differ depending upon what firmware is in the hardware and ISY.
The lack of Motion Sensor traffic in the event trace is not informative.  If it is the PLM that cannot be reached the event trace would not show traffic that does not reach PLM.   if the Motion Sensor is not reaching some other device (and is retrying during the 20 seconds) that traffic never shows in the event trace because that traffic is being sent to an Insteon address other than the PLM.
After putting Motion Sensor into manual linking mode do a Show Device Links Table.  Look for all link records with
E2 01 xx.yy.zz .. .. ..
where xx.yy.zz will be the Insteon devices that receive the motion messages.   By checking Current State of each device with a link record it should show which device(s) are not ACKing the motion message.   Could be a comm issue or the Responder device may have lost the corresponding Responder link record.pointing bac to the motion sensor.
I think it was the broken linc, at one point I had replaced a PLM and that motion sensor might not have gotten the old one removed.  I factory reset it last night and re-added it, will see it it helps any.
This weekend will pull the switch I just put in there, put in a box and attach right at the PLM and see if I get reliable communications or not.
May have to buy that JLR bridge (if I have that name right).  I have enough dual band, access points, filters etc, that I should be having no more issues period.
i tossed out an on/off module the other day that even on the plm plug would not respond reliably.
