Geofence
I had an Iphone 5 and geofence worked almost all the time.  I upgraded to an Iphone 6s and now when leaving, it may take 20 minutes or longer to update the status on the ISY.  My wife has an Iphone 6 and it works almost all the time.  I have checked the settings that I know to check on the Iphone and everything seems OK.  When arriving home, the status updates fairly quickly.  Anyone have any ideas why this is happening?
Hi bconen,
The only immediate thing I can think of is to make sure your Wi-Fi is turned on for your iOS device. With this off, iOS won't be able to see location updates nearly as quick as when Wi-Fi is turned on.
Wes
  • 3 weeks later...
How do you remove a geofence location?
Edited by bconen
Hi bconen,
Open MobiLinc and go to Settings->iBeacon Settings and tap "Edit" to remove.
Wes
When I go to iBeacon, it says plugin required.  I am not using iBeacon, just locations set through "Location Settings".
Sorry bconen I mis-read your post.
Open MobiLinc and go to Settings->Location Settings and swipe from right to left over the location (geo-fence) you want to remove. Tap "Delete".
Wes
