Homekit in v5.x
Envirogreen
I've been trying to follow the posts on this, but I'm not clear on what I should be expecting.
Is home kit expected to be a new module as part of 5.x?
Will these modules require deep development skills to implement or will a casual user be able to use these?
The two things that I am particularly interested in is Honeywell Total Comfort integration and HomeKit.  I'm hoping these both come in 5.x
Are you speaking about Apple Home Kit? If so UDI has no intention of supporting this protocol.
Homekit is not planned as Teken mentioned, primarily due partnership requirements and their effects on UDI as a business. You can search the forum for Homekit, I believe that some folks have found workarounds for using homekit without specific UDI features.
Honeywell's integration is proprietary, like Homekit. I recently saw that there ITTT support for Honeywell. Its still a cloud based solution, so if you lose internet, you lose control from the ISY. If you search the forum for Honeywell ITTT, you'll see recent stories about this topic.
Paul
Edited by paulbates
exactly.   Apple HomeKit.
That's unfortunate.  It seems that Apple home kit will be a popular bridge across multiple HA devices.
Well, perhaps there is a middle ground that can be found. In this resource link it describes a method to use a HUB II with a 994 Series Controller. I would gather the process could be the same for a HUB Pro which is Apple Home Kit enabled: http://forum.universal-devices.com/topic/17271-hub-ii-isy-echo-integration/
You can certainly try with in the 30 day return policy and if it works please do share the outcome and trials with the membership.
looks like I would need Hub Pro for home kit , and doesn't look like this has been done yet...but may be the best/only route forward.
Will need to look at the hub integration further to see if it will also do the honeywell total home comfort, my alternative there is iRule (no cross device integration, but at least 1 UI)
If you decide to do so it would be great it you could document the process and the final outcome. I am sure that many others with like minds would appreciate your first hand experiences in this endeavor.
Blaze a trial and let us all know . . .
      377.2k
