grahamk Posted January 5, 2016 Posted January 5, 2016 I installed HAD on an apache2 web server and when I access the page I get errors underneath the header such as: Error accessing /rest/status: Not Found In my apache error log I see messages such as this: [Mon Jan 04 17:28:40 2016] [error] [client 90.0.0.201] PHP Notice: Use of undefined constant REQUEST_URI - assumed 'REQUEST_URI' in /home/graham/had/rest/isyProxy.php on line 34 This took me to the rest/isyProxy.php program where i noticed these commented lines: //echo "<br>" . time() . "<br>";//print_r($_SERVER[REQUEST_URI]);exit; I uncommented the print;exit line and this is what i see in the browser if i run the program manually: /rest/isyProxy.php This is then sent to the isy via the next line which is a curl call and the call fails - that is how I interpret it anyway. It seems to me that "/rest/isyProxy.php" string is my problem, but i am new to php so I have no idea if i am barking up the wrong tree or ?Any help appreciated!! Thanks, Graham
paulbates Posted January 5, 2016 Posted January 5, 2016 I installed HAD on an apache2 web server and when I access the page I get errors underneath the header such as: Error accessing /rest/status: Not Found In my apache error log I see messages such as this: [Mon Jan 04 17:28:40 2016] [error] [client 90.0.0.201] PHP Notice: Use of undefined constant REQUEST_URI - assumed 'REQUEST_URI' in /home/graham/had/rest/isyProxy.php on line 34 This took me to the rest/isyProxy.php program where i noticed these commented lines: //echo "<br>" . time() . "<br>"; //print_r($_SERVER[REQUEST_URI]);exit; I uncommented the print;exit line and this is what i see in the browser if i run the program manually: /rest/isyProxy.php This is then sent to the isy via the next line which is a curl call and the call fails - that is how I interpret it anyway. It seems to me that "/rest/isyProxy.php" string is my problem, but i am new to php so I have no idea if i am barking up the wrong tree or ? Any help appreciated!! Thanks, Graham Hi Graham You replaced your info in these statements? $isyUser = "admin"; $isyPassword = "admin"; $isyIp = "192.168.0.239"; The placement of the files, especially htaccess, is important. IIRC,it was relative to the root of the web server's default directory Paul
grahamk Posted January 5, 2016 Author Posted January 5, 2016 Hi Graham You replaced your info in these statements? $isyUser = "admin"; $isyPassword = "admin"; $isyIp = "192.168.0.239"; The placement of the files, especially htaccess, is important. IIRC,it was relative to the root of the web server's default directory Paul Yes, I have made the edits and the files are in the right place. They do run as expected, but they are not creating comands that the ISY understands. It appears to me that the unititialized constant REQUEST_URI is my issue, it appears to be filling in the name of the proxy program, not the REST call. Odd. Graham Sent from my SAMSUNG-SM-G900A using Tapatalk
grahamk Posted January 5, 2016 Author Posted January 5, 2016 it occurs to me that If i run the program standalone, the output it gives is correct - so I'm a bit at square one. The proxy is being called because i see the uninitialized constant message from the web server error log. So that does seem to be working.
grahamk Posted January 5, 2016 Author Posted January 5, 2016 I found the issue(s). Just in case anyone is curious: Though it seemed htaccess was working, it was not. I had to go into my /etc/apache2/sites-available/default file and change AllowOverride from None to All. Then I had to link in the mod_rewrite module: ln -s /etc/apache2/mods-available/rewrite.load /etc/apache2/mods-enabled/rewrite.load restarted apache and bingo!!!
