January 5, 201610 yr io_guy, Just gave NodeLink a try for the first time and it's working well, thanks a ton for it. I did have one issue, when adding a new device if there is an underscore in the NodeName it will create the new tab and config entry correctly but trying to change any setting on that tab (even trying to enable verbose logging) causes the NodeLink web server to crash for a bit and the setting not to be saved. Once the underscore was removed from the NodeName it worked well. Also, when starting the NodeLink it complained about a number of "ISY Error: Duplicate node names exist on the ISY". I have devices in one branch and scenes in another, they often have the same name. I ended up changing the names not to overlap while debugging the underscore issue above so not sure if it was just cosmetic or would have caused real issues. Thanks again for a great contribution! EDIT: meant to say I'm on v0.2.6 Edited January 5, 201610 yr by apnar
January 5, 201610 yr Thanks for the feedback. I'll fix the underscore issue. The duplicate node names is just a warning, won't affect functionality.
March 17, 20179 yr I have the same issue and just installed for the first time today so I guess this is not fixed yet. Should I change some of the names of their not duplicate or really just ignore it Jeff
March 19, 20179 yr The duplicate names isn't something for me to fix. It's a warning, you can ignore it.
