How do I delete the Administrative Console
My Administrative Console has gotten all messed up. I need to delete and reinstall it. In the process of trying to find where it was located I got frustrated and went to the file and deleted the folder that it was in. I have reinstalled it, but now it won't open completely. It opens partially and I can't get it to work. How can I uninstall it and reinstall it correctly?
GBC
GBC
Go into the control panel and select Java -> General -> Settings -> Delete Files: Select all three option box's and select delete files. Once done download the Admin Console for what ever firmware you're running such as 4.4.2
Edited by Teken
Thanks, this worked. I discovered that the problem was that I needed to reset my ISY-994i once I had deleted the console. Now everything is working again. Thanks again!
GBC
