September 26, 200719 yr I have created a fast off program that calls my all off lights. Here is my program and steps to the issue I have the question about. If Control 'Master Bed Read Mark' is Fast Off Then Set 'Inside All-Off Scene' Off [*:23bnoyj7]I have some lights on including the reading light with fast off trigger.[*:23bnoyj7]I double tap the reading light and all lights go off.[*:23bnoyj7]I turn some lights back on in the house but not the reading light.[*:23bnoyj7]I double tap the reading light and nothing happens. What it looks like to me is; if the reading light has already had "double tap fast off" done, it will not work if I do a "double tap fast off" again without the light on. Is this something to do with the icon-dimmer, Insteon design, or the ISY?
September 26, 200719 yr Author One other note; if I do a "triple-click super fast off" then it does work. I think the first click of the triple-click is actually setting the dimmer off (even though it is already off) and then it does a fast off with the last two clicks of the triple-click. What do you think is up?
September 27, 200719 yr I've confirmed this as well - good find Mark! If I double-tap off a switch once, the ISY-26 will not recognize a 2nd double-tap off unless something else is done from that switch first. Can this be fixed?
September 27, 200719 yr Yes, this is identical to the non-toggle button problem. It has been fixed and will be in the next beta drop. I've confirmed this as well - good find Mark! If I double-tap off a switch once, the ISY-26 will not recognize a 2nd double-tap off unless something else is done from that switch first. Can this be fixed?
