Question Regarding Individual Device Control
I have a scene that is controlled by two toggle lincs (each are set as controller/responders).  All works well if I turn the switches on/off locally.  If I go into the ISY or through MobilLinc and turn a switch on individually (vs. turning on the scene), it does not control the other switch.  If it's the load switch, it will turn on the scene/light.  If its the non-load switch it won't.  What gives?  Here again, the toggle lincs are in the scence as controller/responders and all works fine locally if the switches turned on/off or if the scene is turned on/off through the ISY or MobilLinc.
It's operating as it's supposed to. If you want to control all the devices in a scene then you need to turn the scene on/off.
