January 24, 201610 yr Hi io_guy, Any plans on adding any support even if Read for Nest in the future? Just curious. Tks.
January 24, 201610 yr I plan on full support eventually. They use a similar API structure to ecobee so it shouldn't be "too" hard. Just lower priority for me since I don't own one and don't really like nest
February 18, 201610 yr I have a node.js script for full Nest control which is available now which I would eventually turn into the node once my ISY will be able to load node definitions correctly PM me if you want the script - it uses network module and variables.
