Replaced 2486D with 2334-233 A-D lights having issues
Replaced with the isy994i, all appeared well, all scenes work properly from keypad. However, the leds in A-D are not responding to scenes activated from elsewhere.  All appears well in the membership tree. Any thoughts?
Edited by paulw
They are showing in the membership as both. Everything looks ok to me in the isy.  The unit works fine except for not acting as responders. Did not have time to spend on this last night, but going to redo the scenes and restore.
Final resolution.... a strange one.
Removed the A-D buttons from their respective scenes (all scenes controlling different devices), and added them back, still no joy as to responding to the scene from other controllers.  The scenes would function properly from the 4 buttons, including the local button lights.
Don't know why I did it, but found if I activated each scene one at a time from a different source, hit the corresponding button on 2334 turning it on and then off, they would all function fine after that.
So far so good.........
Next day, 3 out of 4 stopped working.
Try doing a "restore device", you may have some link records that are incorrect.
Had tried restores, no joy.  Finally removed device from isy, did a factory reset, updated to 4.3.26, reinstalled device and did a restore and all seems well with the world. :-)
