Alexa Connected Home Syntax Glossary
Some users here say that Alexa understands all of the voice controls for Connected Home, and others are having difficulty. Could some of you lucky ones compile a listing of the successful syntax being used to control devices, scenes, and programs? I'll keep an updated list here. Please let me know if any of this is inaccurate or doesn't work well.
Bob
On/Off:
Alexa, Turn On/Off <Device/Scene/Program>  (Note: For programs On=Then, Off=Else)
Alexa, (Turn) (the) < Device/Scene/Program > On/Off
On Level:
Alexa, <Device> 30
Alexa, (Set) (the) <Device> to 30
Alexa, Dim/Brighten <Device>
Alexa, <Device> Brighter
Alexa, Raise <Device>
Alexa, <Device> Dimmer
Alexa, <Device> Lower
Other:
Alexa, Discover Devices - Gets device spoken names from the Portal
Words like "Music", "Radio", "Volume" "Play"or any radio station numbers/call sign collide with Echo's built in functionality and don't work. For example, "Alexa, Playroom Lamp 40" gives a reply "I couldn't find room Lamp."
Edited by Bob P.
With Connected home I'm successful using the following...
Alexa, <device spoken name> On/OFF
Alexa <device spoken name> X%
Alexa <program spoken name> On/OFF
Edit:  I find I don't need to use "turn" or "set"
Jon...
Edited by jerlands
The other thing besides syntax that you need to be careful about is colliding with any of Echo's built in words. I'm trying to control my whole home audio via Echo, but words like "Music", "Radio", "Volume" or any radio station numbers/call sign collide with Echo's built in functionality and don't work. :(
