Mini-Remote Bright/Dim
jgcharlotte
So how do you get a LampLinc to brighten/dim on a RemoteLinc2 (8 scene configured as 4 on/off controls).  Not as a scene, just program control. On and off work fine, I can't get the LampLinc to brighten/dim with a continuous press of the appropriate button.  Monitoring in Admin Console shows the mini-remote varying %, but no effect on the lamp.  I tried all of the controls, fade up/down, bright/dim, etc.
Pressing a button on a Mini-Remote requires a Scene to alter the LampLinc.
Not clear what an ISY Program is attempting.
Can you post the Program
The first on, 'ON' works fine.
The second is one of the variations I tried to achieve dimming with a continuous press.
No luck.
Ok, thanks.
When a Mini-Remote On button is pressed and held the command sequence from the Mini-Remote starts with a Fade Up.
When the button is released a Fade Stop is issued.
Fri 02/12/2016 10:10:57 PM : [iNST-SRX    ] 02 50 1C.2D.53 00.00.01 CB 17 01    LTMCON (UP) - Fade Up
Fri 02/12/2016 10:10:57 PM : [std-Group   ] 1C.2D.53-->Group=1, Max Hops=3, Hops Left=2
Fri 02/12/2016 10:10:57 PM : [D2D EVENT   ] Event [1C 2D 53 1] [bMAN] [1] uom=0 prec=-1
Fri 02/12/2016 10:10:57 PM : [  1C 2D 53 1]     BMAN   1
Fri 02/12/2016 10:11:01 PM : [iNST-SRX    ] 02 50 1C.2D.53 00.00.01 CB 18 00    LTMCOFF(00) - Fade Stop
Fri 02/12/2016 10:11:01 PM : [std-Group   ] 1C.2D.53-->Group=1, Max Hops=3, Hops Left=2
Fri 02/12/2016 10:11:01 PM : [D2D EVENT   ] Event [1C 2D 53 1] [sMAN] [0] uom=0 prec=-1
Fri 02/12/2016 10:11:01 PM : [  1C 2D 53 1]     SMAN   0
Fri 02/12/2016 10:11:01 PM : [D2D EVENT   ] Event [1C 2D 53 1] [sT] [221] uom=0 prec=-1
Fri 02/12/2016 10:11:01 PM : [  1C 2D 53 1]       ST 221
Fri 02/12/2016 10:11:01 PM : [iNST-SRX    ] 02 50 1C.2D.53 00.00.01 C7 18 00    LTMCOFF(00)
Fri 02/12/2016 10:11:01 PM : [std-Group   ] 1C.2D.53-->Group=1, Max Hops=3, Hops Left=1
Fri 02/12/2016 10:11:01 PM : [iNST-DUP    ] Previous message ignored.
An example Program would look like this
RL2-4-B - [iD 009F][Parent 0001]
        Control 'RL2-4 - A' is switched Fade Up
     Or Control 'RL2-4 - A' is not switched Fade Stop
        Set 'LampLinc3' Fade Up
        Set 'LampLinc3' Fade Stop
There are inherent issues with this.  The Program has a delay compared to a Scene.  This will make the LampLinc out of sync with the Mini-Remote On Level.
Sorry I did not put this in previous post.  A Mini-Remote does not have Bright/Dim buttons that raise or lower a small percent for each Bright/Dim button press.  See the Specs section on Smarthome site for possible commands.
Scene Commands Supported: On, Off, Begin Brightening, Begin Dimming, End Brightening, End Dimming, Fast On, Fast Off
Edited by LeeG
      378.6k
