Insteon PIR keeps showing Low Battery after battery change
Has anyone ever experienced this that after changing a battery on a wireless PIR due to a low battery flag… The low battery does not go back to normal or clear..
Everything seems to be working normally… But the low battery light is always on the I SY
Thanks..
Right click on Low Bat node.  Select Query to reset Low Bat.  The Motion Sensor is not actually queried.so no need to put Motion Sensor into linking mode.
Good Morning Lee..
this has resolved my issue.. thank you !
Matt
