Vortec4800 Posted February 29, 2016 Share Posted February 29, 2016 I have several RF devices on my network, like door switches, remotes, etc, all devices that can't accept input without being put into programming mode. These devices show up as grey icons in my ISY. They all work totally fine. The issue is that every time I make a change in my ISY to any devices, or add a new device, the ISY tries to make writes to every device that's like this, and it takes a couple minutes to go through the entire list. Even when I've put these devices into programming mode and let it make any writes to the device, it goes back into this weird mode where it tries to make writes every time. Is this normal, or do I have a configuration issue? Link to comment
LeeG Posted February 29, 2016 Share Posted February 29, 2016 Only one RF device can be put into linking mode at a time. Otherwise the RF devices link to each other. After one RF device update is complete, take it out of linking mode and put the next RF device into linking mode. Link to comment
Vortec4800 Posted February 29, 2016 Author Share Posted February 29, 2016 Even when I've done that, the ISY still transitions each device to this grey icon and tries to do writes to each one every time. The issue isn't that I need to put the RF devices into programming mode, the issue is that the ISY is trying to write to all my RF devices all the time, even when there are no changes being made to those devices specifically. Link to comment
paulbates Posted February 29, 2016 Share Posted February 29, 2016 Are you seeing the 1010 symbols next to devices, is that the symptom? If yes, and if you have scenes and your wireless devices are sensors, this is likely expected behavior. Scenes actually exist in related devices like controllers (sensors) and responders (switches), and those devices have to be touched when a related device changes. If you have the Pro model ISY, you can click an icon to defer wireless updates till you can do them one at a time Paul Link to comment
Vortec4800 Posted February 29, 2016 Author Share Posted February 29, 2016 So I tried performing the writes to each device one at a time, and now everything seems okay. Hopefully it will stay this way instead of just turning grey again, I have quite a few devices to write to! Link to comment
