How to take control of switchlink back from program.
Hi,
I have a motion sensor that controls a switchlink via a program (its very simple). I then need to be able to allow the switch to be controlled manually if a person hits the 'On' paddle while the MS program is running, the light should then stay on and not turn off when the motion sensor times out.
This must be a common real life scenario so there must be a programmatical solution for it but I'm all out of ideas for now.
help appreciaed, thanks.
Wayne.
Thanks Eric, after reading that very nice explanation by Darrell Peters I was able to come up with the following 4 programs but was wondering whether it could be made more efficient. There are no schedules for this program, its runs 24/7.
Wayne
- This program turns on the light if the MS detects motion.
[Mirror Light On]
Program 'Mirror Light Motion Disable' is False
And Status 'Ensuite MS - Sensor' is On
And Status 'Ensuite SL - Mirror Light' is Off
Set 'Ensuite SL - Mirror Light' On
- This program turns the light off when the MS turns off
[Mirror Light Off]
And Status 'Ensuite MS - Sensor' is Off
Set 'Ensuite SL - Mirror Light' Off
- The program below holds a value of either true or false depending on whether the switchlink has been operated manually.
[Mirror Light Motion Disable]
Control 'Ensuite SL - Mirror Light' is switched On
Or Control 'Ensuite SL - Mirror Light' is switched Fast On
Or Control 'Ensuite SL - Mirror Light' is switched Fast Off
Or Control 'Ensuite SL - Mirror Light' is switched Off
- Here we set the [Mirror Light Motion Disable] program back to false when the motion sensor turns off.
[Check Motion Status]
Control 'Ensuite MS - Sensor' is switched Off
Run Program 'Mirror Light Motion Disable' (If)
I am not 100% clear on what you are wanting to do when someone taps the switch.
Are you looking to turn the light on when someon taps the switch AND ignore the motion sensor completely...forever, until someone turns the light off manually and then go back to motion mode?
or
Are you looking to turn the light on OR off when someone taps the on/off paddle on the switch...but still allow the motion sensor to turn the light off when motion is no longer sensed?
This is what I'm doing with the above code and it works perfectly, but I'm wondering whether it could be written more efficiently
Wayne
Wayne
Unless I am mistaken, it's not exactly what you are doing...it appears to me by the programs posted that once the Motion Sensor goes off, then it resets everything and turns out the light. What I was asking is if this is what you wanted, or did you want motion sensing completely disabled until the user pushes a button again.
Since you say it works perfectly how you want it, then I think it is fine. I prefer the methods that Darell posted in the link I posted, but that is just me. I am not sure efficiency has anything to do with it though...just that I think it gives more control from within ISY and is easier to manage.
Here is a description of what the program does, its slightly different to what Darell posted but it does work the way I want it to work. My question is, did I do it in the most programatically efficient/elegant way. I'm not at all use to this type of programming and was looking for better techniques.
Scenario:
Person walks into room and light automatically turns on by motion sensor.
Person also has ability to switch light off or on again via tapping paddle.
Person leaves room with light on or off.
Motion sensor times out and turns off the light.
**Added
The above scenario is not correct. Here is the revised scenario.
If person turned light off then Motion sensor times out and is re-enabled.
If person turned light on then motion sensor remains inactive until light is turned off.
Eric, you are correct, the code is not doing this so I'll try to correct it and post the update.
Wayne
[Mirror Light Off]
Shouldn't this program also check to see if the light is "NOT OFF" already in its conditions?
Yes it should. Thanks.
Hi Eric, you are correct, the code is not doing what I wanted. I'll try to correct it and post the update.
Wayne
Wayne
That is what I thought you might want...and is a bit more complicated. To much "Christmas Cheer" for me to post anything that might be closely related to coherent programming tonight.... :?
Merry Christmas...and post what you have corrected when you get it!
Merry Christmas... Christmas cheer is always good :)
After too much thinking I think it might be close if not there, although to my eyes the code looks ugly with too many programs. At this stage I'm leaving out the Fast On's/Off's.
[Motion Turn On]
Control 'Ensuite MS - Sensor' is switched On
And (
Program 'Motion Disable (On)' is False
And Program 'Motion Disable (Off)' is False
[Motion Turn Off]
And Status 'Ensuite SL - Mirror Light' is On
And (
[Motion Disable (On)]
[Motion Disable (Off)]
Run Program 'Motion Disable (On)' (If)
[Reset Motion Disable]
Run Program 'Motion Disable (Off)' (If)
Assuming that you want to use the off time setup in the motion sensor (which is how you have your programs setup) then I would do it this way:
In my example, the light is called "Test Light" and the motion sensor is called "Test Motion Sensor".
Setup a Folder for it (I called it Test Motion) with the following conditions:
Folder Conditions for 'Test Motion Folder'
       Control 'Test Light' is not switched On
   And Control 'Test Light' is switched Off
Whenever someone turns on the light, it will disable the program(s) in the folder.
Inside this folder is the following program:
Program Name: Test Motion Control
       Control 'Test Motion Sensor' is switched On
   And Control 'Test Motion Sensor' is not switched Off
       Set 'Test Light' On
       Set 'Test Light' Off
This should work as you want: When someone enters the room, the light will turn on when the motion sensor sends the on command and will turn off when the motion sensor sends the off command.
If the person taps the ON button on the light control, it will disable the folder conditions and consequently disable the motion program from working. It will stay disabled until someone turns the light out by tapping the OFF button. You could add the Fast On and Fast Off buttons accordingly if you want.
You could have another program that waits a LONG time, then turns the light out (just in case someone forgets) like this:
Program Name: Test Light On To Long
       Control 'Test Light' is switched On
   And Control 'Test Light' is not switched Off
       Wait  1 hour
The only issue with this last one is that it will keep your Motion sensing disabled...the light will turn out, but the folder conditions will not be reset and therefore the light will have to be turned off or on manually again to get the motion sensing enabled. Maybe OK, since this would be an indication that someone left the light on too long or something. Just an idea...
I did not run this through any paces, but it should work. Let me know what you think.
Eric,
The ability for control to revert back to the sensor (after it times out) if the 'Off' paddle is tapped is a must so I dont think that will work.
It seems to work as intended at the moment, if you or anyone can point out any flaws or can reduce the number of programs (currently 5) without compromising on functionality that would be great.
Wayne
Eric,
Wayne
What I wrote gives you that ability. In fact, it works just like your 5 programs do, only with 1 program and folder conditions. If you tap the OFF button, it will shut off the light and re-enable the motion sensor.
The only thing that wouldn't is the very last (optional) program that I posted just in case you wanted to turn the light out after a long period of time if someone forgets. This is optional and not needed to work like you stated in your updated requirements. If someone turns on the light manually, it will stay on forever (and the motion sensing will stay disabled) until they tap the off button....which is the same way it works in your program.
Hi Eric,
I just tried it and it doesn't seem to function, for some reason the light doesn't initially turn on via the sensor. I'm not sure why but probably only requires a small change.
Would be good if we can get it to work because its much smaller and would be more efficient.
Wayne
       Set 'Test Light' On
Wayne,
Can you post the folder conditions you have and the program that you have? I've tested it and it works...though I simulated the motion sensor with a keypad button...but should work the same.
Eric,
I just tested the sensor again and this code is definately not turning on the light. I then changed the code to my code and it started working, so the sensor and light are working.
Here is a 'copy to clipboard' of the folder code followed by the program code within the folder.
[Folder Test Code]
       Control 'Mud Room SL - Light' is not switched On
   And Control 'Mud Room SL - Light' is switched Off
[Test Motion Control]
       Control 'Mud Room - Sensor' is switched On
   And Control 'Mud Room - Sensor' is not switched Off
       Set 'Mud Room SL - Light' On
       Set 'Mud Room SL - Light' Off
I think I see the problem...it is in the folder conditions. The switch must be toggled off once to get the thing jump started. I did not have this problem, because I tested the folder conditions right away when I put it in.
I will take a look (and please, someone jump in if you have a fix) but in the mean time, try putting it back it in and then check the Folder on the program summary tab...I am betting it will be FALSE. Tap the light on then tap it off and it will go TRUE then it will start working correctly.
Let me know what you find.
Eric,
[Folder Test Code]
Yes the folder value is 'FALSE' on startup and tapping the paddle changes it to true.
Wayne
Wayne
So I assume it worked correctly after that?
Off to the Aquarium today with the family... No automation playtime for me today according to the wife! :cry:
Yes it worked correctly once the paddle was tapped, but I'd still have to add in dimming and fast on/off and it appears that the programs I'm using currently handle both of those.
We would pretty much need to solve that requirement to have to tap the paddle in order to kick off the process. I can imagine it could become an issue if for any reason ISY lost power or when it requires rebooting etc, then we would have to walk around and tap all the paddles. Its not a clean approach but once that issue is solve we are off and running.
Sounds like a very nice day out, you'll probably come back with the solution, ready to go :)
Thanks for your help,
Wayne
