Volume - 2 vs 3XX
Teken
I wanted to know if others are experiencing the same volume issue I see here? If the volume is set to 2 its pretty quiet but if you ask her to adjust it to 3 the volume just shoots up.
Going to 3, 4, 5 the volume appears to be a steady incremental change in dB level. One would have guessed with all the digital electronics the volume would be smoother.
The volume ring works perfectly fine and since its late I haven't had the chance to confirm if the ring has any impact to the disparity of the volume from 2-3.
I gather not because the ring volume has been adjusted many times in the past to obtain the correct volume.
Edited by Teken
I, too have noticed this non-linearity. Although it shouldn't be a big deal, it is kind of annoying.
That's great to know someone else is seeing the same issue. Sometimes I just need volume 2 to be 2.50, but when you ask the system to go from 2 to 3 its like 2-4.5?!?!
But like I said if you're on volume 3 and go to 4, 5, 6, it seems to be a uniform stepped output. I suppose the reality is my lazy aszz needs to get off the chair and dial it down to the exact level I want.
Ha . . .
      380.1k
