March 11, 201610 yr Hello, Is there a document out there that gives a step by step procedure to upgrade a 2412 PLM to a 2413s PLM? the Dual band PLM is a VI.B. Thanks Edited March 11, 201610 yr by Michaelv
March 11, 201610 yr Hello, Is there a document out there that gives a step by step procedure to upgrade a 2412 PLM to a 2413s PLM? the Dual band PLM is a VI.B. Thanks Hi Michael This is the procedure to replace a PLM. It will be the same for replacing the 2412 with a PLM. If your ISY was powered by the 2412, you'll need to get a power supply for it as the 2413 does not provide power. You may want to consider how you have access points / range extenders located, as the PLM will now be sending out insteon messages via RF Do not use "Delete Modem", it is not applicable to a replacment. Paul Edited March 11, 201610 yr by paulbates
March 11, 201610 yr Author Thanks Paul, I will look into that. Modems still sends signals over powerlines as well, yes?
March 11, 201610 yr If you have two properly located Range Extenders/Access Points as indicated by the Beacon/4-tap test, then the dual-band PLM will serve to increase reliability and range of the Insteon network. In any case, the new PLM will not be detrimental at all.
March 11, 201610 yr The Beacon or 4-tap test is performed manually as per the Owner's Manual instructions. It need be done only once, ever, unless the Range Extender/Access Point is moved to a different location (e.g., plugged in someplace else). A Range Extender/Access Point is not even known to the ISY nor need it be. The Range Extender/Access Point simply repeats Insteon signals both on the power line and via RF no matter where it's plugged in, but location is critical for the pair to bridge the opposite legs of the split, single-phase power supply.
