March 11, 20169 yr Had to factory reset KPL 2486D. I reset it into an 8 button. When I add it to the ISY, I still only get 5 nodes. I selected 8 button in the drop down. Any ideas?
March 11, 20169 yr Hi Here you go, page 17 Use the steps to tell the keypad its an 8 key Paul (edit: I fixed the link) http://cache.insteon.com/pdf/2486D.pdf Edited March 11, 20169 yr by paulbates
March 11, 20169 yr The KPL will still be reported as a 5-button KPL, but should have 8 nodes. When you reset the KPL, did you have 8 individual button LED (e.g., the top two and bottom two behaved individually)? Which drop down menu allowed you to select 8-button?
March 11, 20169 yr Author Thanks Paul The only part I missed the first time was holding the buttons for 3 seconds after. That worked!
March 11, 20169 yr I have problems every time I try to change a keypadlinc's button config. Takes me 10 tries or more to do the conversion. Is there a trick to it?
March 11, 20169 yr ScottAvery It would be helpful to know what button and configuration being changed as well as device firmware.
March 11, 20169 yr I have problems every time I try to change a keypadlinc's button config. Takes me 10 tries or more to do the conversion. Is there a trick to it? Yes, having the patience to wait the designated time between steps
