Replacement ISY - Motion Sensor?
bdslack
I have searched but cannot find...
I replaced a bad ISY and imported my database - BOOM back in business!
Except that all the motion sensors would not work.
I pulled them all down - pulled all the batteries - did a hard reset on one.
Removed them all from my ISY Program (Deleted and removed links).
Tried to link them using the menu Link Management - Sensor Motion Sensor.
These are 2842-222 3413 Rev.2's.
I have about 9 of them.
Pressed the button for 5 seconds until blinking.
Software responds with:
"The Following Devices Could Not Be Added:
27.8A.1E (2842-222) INSTEON Motion Sensor v.41
  - Cannot add Insteon Device"
Any ideas at all?
Edited by bdslack
Is your motion sensor within close proximity to a dual band device.
Make sure that your ISY firmware and the UI are the same version number.
Thanks for the reply.
Both the UI and ISY show firmware at v4.3.26.
I have over 100 dual band devices everywhere. Even went upstairs next to the PLM and nothing. I have 8 switches within ten feet of me now.
I know they are connecting because if I try and link it will show v.0.0 and once I set the sensor into linking mode it will flip instantly over from v.00 to v.41 (the actual sensor version I believe). I have also set the sensor into linking mode first and then tried to link - no luck there either. Is there a version of the ISY that can't connect to motion sensors (thinking I might have bought the incorrect ISY?).
Log: (I don't know why the ELK is doing this?)
Sun 03/27/2016 10:15:41 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:15:41 PM : [ELK         ] Connect
Sun 03/27/2016 10:15:41 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:15:48 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:15:48 PM : [ELK         ] Connect
Sun 03/27/2016 10:15:48 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:15:56 PM : Elk Query All Failed, requesting retry
Sun 03/27/2016 10:15:58 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:15:58 PM : [ELK         ] Connect
Sun 03/27/2016 10:15:58 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:16:05 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:16:05 PM : [ELK         ] Connect
Sun 03/27/2016 10:16:05 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:16:12 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:16:12 PM : [ELK         ] Connect
Sun 03/27/2016 10:16:12 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:16:19 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:16:19 PM : [ELK         ] Connect
Sun 03/27/2016 10:16:19 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:16:24 PM : [27 8a 1e    ] Added to list of devices to link to ISY
Sun 03/27/2016 10:16:26 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:16:26 PM : [ELK         ] Connect
Sun 03/27/2016 10:16:26 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:16:31 PM : Elk Query All
Sun 03/27/2016 10:16:34 PM : [ELK         ] Disconnect
Sun 03/27/2016 10:16:34 PM : [ELK         ] Connect
Sun 03/27/2016 10:16:34 PM : [ELK         ] Connect Successful
Sun 03/27/2016 10:16:37 PM : [27 8A 1E 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Sun 03/27/2016 10:16:37 PM : [27 8A 1E 0  ] Failed to add device, reason 1
Thanks Jon,
I disabled the Elk in the software.
No longer getting the traffic. Still can't link the motion sensors...
Sun 03/27/2016 10:55:49 PM : [27 8a 1e    ] Added to list of devices to link to ISY
Sun 03/27/2016 10:55:52 PM : [27 8A 1E 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Sun 03/27/2016 10:55:52 PM : [27 8A 1E 0  ] Failed to add device, reason 1
Sun 03/27/2016 10:55:52 PM : [All         ] Writing 0 bytes to devices
Edited by bdslack
Failed to add device, reason 1 <<--  994i has a limit of 255 node links, 994i Pro has a limit over 900.  If you don't have the Pro you may have reached the limit.
Jon...
Upgraded. I had a PRO originally that came with my ELK. I had too many devices / programs and that is what was causing the issue.
The ELK issue - just needed to change the port setting to the non-secured 2101 port and that fixed the communication issue.
Got all the motion sensors reinstalled and reprogrammed.
Thanks again!
Which ISY Pro did you upgrade from and to? A 99i to a 994i?
      37.6k
      376.2k
