Help with KPL's, scenes and IR codes
I have really tried to search the Wiki and the forums for these answers but I have not been able to find these particular situations.
I have created a scene controlled by a key pad linc button and it works fine. I want to be able to run that scene by pressing another Key pad button on a different key pad. How is it done?
Then , I want to be able to control the same scene with a remotecontrol / IR linc. How is that done?
MV
For the additional Keypadlinc, drag the second button to the scene and drop it (or right click on it and go to "Add to Scene" and select the scene you want to add it to). Add it as a Controller for the scene and it will work as you expect.
I can't help with the second question, I don't have an IRLinc.
MV
Simply add the new KPL button as a controller to the scene. Then select that button in the scene and use Copy Scene Attributes from ...
The same way :)
Rand
