isy944i Power Supply
The power supply I received with my ISY944i has failed.  The ISY stopped working and I noticed that the network connectivity failed as well.  LED was dim so I tried a different power supply I had (5v, 1A, appears to be a 3.5mm plug) and it started up instantly.  Fixed.
What are the power supply requirements?   Can I use any 5V, 1A, 3.5mm jack power supply?
I am also using an Insteon 2413S PowerLinc Modem (PLM).  I saw on the Smarthome site that the PLM can power the ISY.  MY ISY was purchased in 2012, so not sure if this applies to mine.
Edited by Scott MS
I think I can answer my own question.  You can buy a replacement power supply at universal devices.  I just bought two.
https://www.universal-devices.com/sales/
Also, it appears that if you use the dual-band PLM, like the 2413S I have, you need the external power supply for the ISY.  Please correct me if I am wrong.
Edited by Scott MS
Nope, you're right -- the 2413S does not supply power (unlike the 2412S, which did).
Just had the same issue w/ my ISY994iZw that was less than 2 months old. I thought my ISY died at first, but since no lights were illuminating I gave a spare power supply a shot and it fired back up. I contacted support and Michel promptly sent a replacement.
You can also use higher voltage power supplies as ling as the polarity is correct. I've been using a 12VDC supply of which I have plenty.
  • 9 months later...
Got the the PLM (2413) and also moved it upstairs. All the writes have now gone through. I will see how it operates now (hopefully better).
Thanks for the help everyone!
