Need help with a timer program controlling an insteon outlet
I have a program that controls an outlet to be "on" for 2 hours then "off" for a minute then "on" again for 2 hours etc.
$Allow_to_Run is 1
Repeat Every 1 minute
Set 'Outlet' On
Wait 2 hours
Set 'Outlet' Off
Else (blank)
I would like to enhance the program to only do this 4 times and then set the outlet "off" for 16 hours, then repeat the 2 hour "on/off" cycle again.
Thanks in advance for your help
Logically, i suppose you could try:
$allowtorun is 1
Repeat 4 times
Set outlet on wait 2 hours
Set outlet off
Wait 1 minute
Repeat
Run next program (then path)
Halt next program
Next program:
Nothing
Wait 16 hours
Run last program (if path)
One program could do it by calling itself
    $Allow_to_Run is 1
    Repeat for 4 times
        Set 'Outlet' On
        Wait 2 hours
        Set 'Outlet' Off
        Wait 1 minute
    Repeat 1 times
    Wait 16 hours
    Run (if) program.self
     Set 'Outlet' Off
