WebControl - Adding 2nd WC8 ISY only populates some nodes
Hello io_guy,
I am having an issue adding a second WC8 to ISY. After creating the device and pressing add nodes to ISY only some of the nodes populate. I get variables, and outputs 2,4,6 and 8. No climate or inputs page.
Also once I hit the add nodes button DSC and the first wc I added stop reporting and the log indicates the ISY was not responding.
I have tried it numerous times always with the same result.
I have sent you a pm with the before and after config.xml for you to look at.
Tim
Tim, keep hitting add nodes, it's likely just failing to install some of them. This happens on some systems, I can't do anything about it until UDI fixes their side.
I had this when I first set up.  Hitting Add all nodes brought in all of the missing items.
-Xathros
I plan to automate the node install process but this can't be done until UDI fixes the firmware. Right now a node install fail gives the same error code back as one that already exists, so there's no way to determine what's what and it'd be in an endless loop.
UDI are aware and plan to fix.
