July 4, 20169 yr I am trying to integrate my Ecobee and ISY. I have the NodeLink installed and running on a Pi. The issue is installing the Node Server in ISY. I downloaded the nodesetup.zip file from the automation shack and tried to import it to ISY under the Network Resources tab but nothing seems to happen. I don't get the menu in the ISY documentation a "Node Severs" tab next to tools and help tab. What am I doing wrong? Thanks
July 4, 20169 yr It's not under network resources, it's under the Node Servers. I'm assuming you're running 5.0.X? Post screenshots, not really following what you're saying
July 4, 20169 yr Author That is the issue I don't have a node server tab! I have the ISY portal which includes the Network plug in. No node server tab though. Edited July 5, 20169 yr by Basenji
July 5, 20169 yr NodeLink has nothing to do with Network Resources and requires ISY firmware 5.0.x or better. Edited July 5, 20169 yr by larryllix
July 5, 20169 yr Author I am running ISY 4.4.6 but the current beta is 4.5.0 on the web site. Where do I get 5.0? This is probably my issue
July 5, 20169 yr http://forum.universal-devices.com/topic/18711-release-504-alpha-is-now-available/ It is alpha software so don't expect everything perfect yet.
July 5, 20169 yr Author Thanks, that did the trick for the admin console. I cleared my Java and installed the new applet. Now I can not login to ISY. Did the credential change from admin/admin?
July 19, 20169 yr Thanks, that did the trick for the admin console. I cleared my Java and installed the new applet. Now I can not login to ISY. Did the credential change from admin/admin? Known bug with 5.0.x. Please reset your password: http://wiki.universal-devices.com/index.php?title=Resetting_Your_ISY
