Insteon thermostat
Hi All
I have installed a new thermostat, Insteon . the other one quit working the current  temp doesn't seen to be updating to the ISY, the humidity does. the house is 72 the ISY shows 74  I think I remember that it doesn't update every degree but how often should it
What's the result if you query the thermostat?
Hi Stu
If I query it it will update to what the thermostat says
Well, that's good. Other than viewing the temperature, do you need/want to take action based on the ambient temperature?
BTW, I don't know when the thermostat updates the ISY on its own? But, programs based on temperature function correctly.
Hi Stu
I do have a program that sends me a text when the house drops below a certain temp, It gets cold here in MN and if I'm gone and the heat goes out it good to know.
As a test, create a program that will triggers if the temperature changes one degree up or down. Email is slow, a text is better, a light turning on is best. When you get the message, observe what the ISY shows.
As a test I have a potlamp (not a grow op) over my desk that flashes every time a setpoint change is made on my thermostat to prove my stat programs are working correctly.
If you have ISY v5.xx firmware you can stuff the temperature into a variable each time it changes.
If you really want to find out you can assign 5-10 sequential variables to the task, and shift them all down one and shove the latest temperature into the top variable each time the temperature changes.
Then you will have a record of the last 5-10 temperature changes for your examination.
It's your ISY, your variables, and your time,,,play with it and have fun. costs nothing.
    InsteonStat temp <9999
   var10 = var9
   var9 = var8
   var7 - .....
    var2 = var1
     var1 = InsteonStat Temp
