Failed to Write
Was getting the unable to determine Insteon Engine when adding a new 7.8 version Switchlinc Dimmer today to replace one I fried yesterday.
Therefore upgraded to 4.5.1 to see if that problem was resolved, so far so good on that issue.
However, I have seen this error on the 4.4.x I was on, and still seeing it in 4.5.1 as well, see the bottom of the logs.
I am also curious why I am seeing 00.b8.4c in there when I have no devices that are 00.b8.4c
Alan
Mon 07/25/2016 10:54:48 AM : [41 b8 4c    ] Added to list of devices to link to ISY
Mon 07/25/2016 10:54:48 AM : [INST-TX-I1  ] 02 62 41 B8 4C 0F 0D 00
Mon 07/25/2016 10:54:48 AM : [INST-ACK    ] 02 62 41.B8.4C 0F 0D 00 06                 (00)
Mon 07/25/2016 10:54:48 AM : [INST-SRX    ] 02 50 20.B8.4C 19.72.DE 2B 0D 02           (02)
Mon 07/25/2016 10:54:48 AM : [Std-Direct Ack] 20.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:54:48 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:54:48 AM : [INST-SRX    ] 02 50 41.B8.4C 19.72.DE 23 0D 02           (02)
Mon 07/25/2016 10:54:48 AM : [Std-Direct Ack] 41.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Mon 07/25/2016 10:54:48 AM : [INST-TX-I1  ] 02 62 41 B8 4C 0F 10 00
Mon 07/25/2016 10:54:48 AM : [INST-ACK    ] 02 62 41.B8.4C 0F 10 00 06          ID-REQ (00)
Mon 07/25/2016 10:54:48 AM : [INST-SRX    ] 02 50 1F.B8.4C 19.72.DE 2B 10 00    ID-REQ (00)
Mon 07/25/2016 10:54:48 AM : [Std-Direct Ack] 1F.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:54:49 AM : [INST-SRX    ] 02 50 7B.B8.4C 01.20.45 8B 01 78           (78)
Mon 07/25/2016 10:54:49 AM : [Std-Broadcast] 7B.B8.4C-->01.20.45, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:54:49 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:54:58 AM : [INST-TX-I1  ] 02 62 41 B8 4C 0F 10 00
Mon 07/25/2016 10:54:58 AM : [INST-ACK    ] 02 62 41.B8.4C 0F 10 00 06          ID-REQ (00)
Mon 07/25/2016 10:54:58 AM : [INST-SRX    ] 02 50 1F.B8.4C 19.72.DE 2B 10 00    ID-REQ (00)
Mon 07/25/2016 10:54:58 AM : [Std-Direct Ack] 1F.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:54:58 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:54:58 AM : [INST-SRX    ] 02 50 41.B8.4C 19.72.DE 23 10 00    ID-REQ (00)
Mon 07/25/2016 10:54:58 AM : [Std-Direct Ack] 41.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Mon 07/25/2016 10:54:58 AM : [INST-SRX    ] 02 50 41.B8.4C 01.20.45 87 01 78           (78)
Mon 07/25/2016 10:54:58 AM : [Std-Broadcast] 41.B8.4C-->01.20.45, Max Hops=3, Hops Left=1
Mon 07/25/2016 10:54:58 AM : [41 B8 4C 0  ] Calibrating engine version
Mon 07/25/2016 10:54:58 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Mon 07/25/2016 10:54:58 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Mon 07/25/2016 10:54:59 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:54:59 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:54:59 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:54:59 AM : [INST-ERX    ] 02 51 41 B8 4C 19 72 DE 11 2F 00 00 01 0F FF 00 AA 00 19 72 DE 00 1C 01 92
Mon 07/25/2016 10:54:59 AM : [Ext-Direct  ] 41.B8.4C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Mon 07/25/2016 10:54:59 AM : [41 B8 4C 0  ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8)
Mon 07/25/2016 10:54:59 AM : [41 B8 4C 1  ] Start : Adding device to ISY
Mon 07/25/2016 10:54:59 AM : [41 B8 4C 1  ] Finish : Adding device to ISY was Successful
Mon 07/25/2016 10:54:59 AM : [41 B8 4C 1  ] Link    0 : 0FF8 [A2001972DEFF1F01] Saving  [A2001972DEFF1F01]
Mon 07/25/2016 10:55:00 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] Saving  [E2011972DE010001]
Mon 07/25/2016 10:55:00 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1
Mon 07/25/2016 10:55:00 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2E 00 01 00 00 00 00 00 00 00 00 00 00 00 00 D1 06        (00)
Mon 07/25/2016 10:55:00 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2E 00           (00)
Mon 07/25/2016 10:55:00 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:55:00 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:55:01 AM : [INST-ERX    ] 02 51 41 B8 4C 19 72 DE 11 2E 00 01 01 00 00 20 20 1C FE 1F 00 00 00 00 00
Mon 07/25/2016 10:55:01 AM : [Ext-Direct  ] 41.B8.4C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Mon 07/25/2016 10:55:01 AM : [D2D EVENT   ] Event [41 B8 4C 1] [OL] [255] uom=0 prec=-1
Mon 07/25/2016 10:55:01 AM : [  41 B8 4C 1]       OL 255
Mon 07/25/2016 10:55:01 AM : [D2D EVENT   ] Event [41 B8 4C 1] [RR] [28] uom=0 prec=-1
Mon 07/25/2016 10:55:01 AM : [  41 B8 4C 1]       RR  28
Mon 07/25/2016 10:55:01 AM : [INST-TX-I1  ] 02 62 41 B8 4C 0F 19 00
Mon 07/25/2016 10:55:01 AM : [INST-ACK    ] 02 62 41.B8.4C 0F 19 00 06          LTSREQ (LIGHT)
Mon 07/25/2016 10:55:01 AM : [INST-SRX    ] 02 50 17.B8.4C 19.72.DE 2B 01 00           (00)
Mon 07/25/2016 10:55:01 AM : [Std-Direct Ack] 17.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:55:01 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:55:01 AM : [INST-SRX    ] 02 50 41.B8.4C 19.72.DE 23 01 00           (00)
Mon 07/25/2016 10:55:02 AM : [Std-Direct Ack] 41.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Mon 07/25/2016 10:55:02 AM : [D2D EVENT   ] Event [41 B8 4C 1] [ST] [0] uom=0 prec=-1
Mon 07/25/2016 10:55:02 AM : [  41 B8 4C 1]       ST   0
Mon 07/25/2016 10:55:02 AM : [D2D EVENT   ] Event [41 B8 4C 1] [OL] [255] uom=0 prec=-1
Mon 07/25/2016 10:55:02 AM : [  41 B8 4C 1]       OL 255
Mon 07/25/2016 10:55:02 AM : [D2D EVENT   ] Event [41 B8 4C 1] [RR] [28] uom=0 prec=-1
Mon 07/25/2016 10:55:02 AM : [  41 B8 4C 1]       RR  28
Mon 07/25/2016 10:55:02 AM : [41 B8 4C 0  ] Successfully added device
Mon 07/25/2016 10:55:02 AM : [All         ] Writing 16 bytes to devices
Mon 07/25/2016 10:55:03 AM : [41 B8 4C 1  ] Link    0 : 0FF8 [A2001972DEFF1F01] Writing [A2001972DEFF1F01]
Mon 07/25/2016 10:55:03 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F FF 08 A2 00 19 72 DE FF 1F 01 8F
Mon 07/25/2016 10:55:03 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F FF 08 A2 00 19 72 DE FF 1F 01 8F 06        (00)
Mon 07/25/2016 10:55:04 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:55:04 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:55:04 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:55:13 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F FF 08 A2 00 19 72 DE FF 1F 01 8F
Mon 07/25/2016 10:55:13 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F FF 08 A2 00 19 72 DE FF 1F 01 8F 06        (00)
Mon 07/25/2016 10:55:13 AM : [INST-SRX    ] 02 50 41.B8.4C 19.72.DE 27 2F 00           (00)
Mon 07/25/2016 10:55:13 AM : [Std-Direct Ack] 41.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Mon 07/25/2016 10:55:14 AM : [MNG-LNK-RSP ] 02 6F 40 E2 00 41 B8 4C 01 20 45 06
Mon 07/25/2016 10:55:14 AM : [PLM         ] Group   0 : Writing Controller Link matching [41 B8 4C 1  ] Link    0 : 0FF8 [A2001972DEFF1F01]
Mon 07/25/2016 10:55:14 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] Writing [E2011972DE010001]
Mon 07/25/2016 10:55:14 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:55:14 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:55:14 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:55:14 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:55:14 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:55:23 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:55:23 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:55:24 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:55:24 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:55:24 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:55:33 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:55:33 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:55:34 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:55:34 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:55:34 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:55:37 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] *Failed Writing [E2011972DE010001]
Mon 07/25/2016 10:56:48 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] Writing [E2011972DE010001]
Mon 07/25/2016 10:56:48 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:56:48 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:56:48 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:56:48 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:56:48 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:56:57 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:56:57 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:56:58 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:56:58 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:56:58 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:57:07 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:57:07 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:57:07 AM : [INST-SRX    ] 02 50 00.00.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:57:07 AM : [Std-Direct Ack] 00.00.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:57:07 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:57:11 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] *Failed Writing [E2011972DE010001]
Mon 07/25/2016 10:57:20 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] Writing [E2011972DE010001]
Mon 07/25/2016 10:57:20 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:57:20 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:57:21 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:57:21 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:57:21 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:57:30 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:57:30 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:57:30 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:57:30 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:57:30 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:57:39 AM : [INST-TX-I2CS] 02 62 41 B8 4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73
Mon 07/25/2016 10:57:39 AM : [INST-ACK    ] 02 62 41.B8.4C 1F 2F 00 00 02 0F F7 08 E2 01 19 72 DE 01 00 01 73 06        (00)
Mon 07/25/2016 10:57:40 AM : [INST-SRX    ] 02 50 00.B8.4C 19.72.DE 2B 2F 00           (00)
Mon 07/25/2016 10:57:40 AM : [Std-Direct Ack] 00.B8.4C-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Mon 07/25/2016 10:57:40 AM : [INST-DUP    ] Previous message ignored.
Mon 07/25/2016 10:57:44 AM : [41 B8 4C 1  ] Link    1 : 0FF0 [E2011972DE010001] *Failed Writing [E2011972DE010001]
None of the messages from 41.B8.4C have a correct first byte.
Suggest doing a factory rest of Switchlinc dimmer and trying again.  If that does not resolve look for something interfering with inbound communicating.
      37.6k
      376.3k
