Reverse LED for Keypadlinc button
I have a keypadlinc button setup as a controller for a water valve controlled by an IOLinc.  Currently, the LED lights up when the button is pressed and the water valve is turned to ON.  What I want to have happen is that the button is lit only when the IOLinc, and therefore the water valve, is in the OFF state.  How do I do this?
The state of the button LED is actually controlled by the sensor, not the relay. You'll need to create a scene that contains the button LED only and control the scene using the relay as a program trigger.
Edited by stusviews
