All Devices Trigger for No Reason
For the 2nd time in about 6 weeks, in the middle of the night, all my INSTEON devices controlled through my ISY994i which were all off at the time, turned on!  All of them!  Is there any way to debug why this is happening?
Was it around 3:00 AM when the System Query is run?
Do you have any IOLinc modules using the Sensor Reversed option in the ISY Administrative Console?
What firmware revision are you running and is the UI the same version?
You can use the Search function here to find others reporting basically the same problems and possible fixes..
